January 30, 2009, 10:59 |
Mass Flow Imbalance
I am runing a CFX analysis on a fluid pump, and when I look at the results, everything seems to be in order.
However, when I compare massflow at inlet to massflow at outlet, the outlet massflow is exactly one-half that of the inlet (the inlet massflow is correct according to hand calcs). When I check the massflow out of the impeller, it is the same as that at the inlet so something is happening in my fluid out domain where the massflow out of the fluid out domain is precisely half of the massflow into the fluid out domain. Does anyone have any ideas on why this is? Does this mean my run is not converged? I found it odd that it is exactly half of my inlet mass flow (to about .00001 decimal places). |
January 30, 2009, 11:45 |
Re: Mass Flow Imbalance
Update:
Looking at my out file, I see that domain imbalance for fluid in is 50%. Anyone have any ideas on why this might be? +--------------------------------------------------------------------+ | Mass-Water at 25 C-fluid_in | +--------------------------------------------------------------------+ Boundary : inlet 1.2643E+02 Domain Interface : fin_to_impeller (Side 2) -6.4413E+01 Domain Interface : fin_to_wear_ring_gap (Side 1) 1.1992E+00 ----------- Domain Imbalance : 6.3213E+01 Domain Imbalance, in %: 50.0000 % |
January 30, 2009, 14:22 |
Hi Ed,
Do you have a frame change with different pitches? What type of boundary conditions have you applied? -CycLone |
January 30, 2009, 14:30 |
My BCs are velocity inlet and static pressure outlet. I have frozen rotor frame change, but there is no pitch. All surfaces at the domain interfaces are 1:1. I partitioned the model into 3 partitions, so maybe there was an error transferring data there?
January 30, 2009, 14:34 |
I would check the interfaces. CFX won't get the mass flow out by 50%, so I suspect something is set up wrong.
January 31, 2009, 07:20 |
if you check, CFX solver again. there has information, how mass imbalance calculated. just see that once. . the mass will be distribted around the boundary conditions, other than inlet and outlet.
Running dieselFoam error | adorean | OpenFOAM Running, Solving & CFD | 119 | February 1, 2016 14:41 |
Species mass flow inlet | lorenz | FLUENT | 3 | March 15, 2012 07:26 |
Mass flow imbalance in transient state | Ton | CFX | 3 | June 2, 2009 01:05 |
Mass flow and U-Mom flow in CFX | Zhihua Xie | CFX | 0 | September 3, 2007 09:49 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 04:18 |
