material property in steady state CHT simulation
Old   February 20, 2009, 06:27
Default material property in steady state CHT simulation
NVSD BABU
HI
iam doing a steady state CHT simulation, i know the thermal conductivity of the one of the solid but i dont the other properties, i know that in steady state solution only thermal conductivity is sufficient, but when we are intializing a new material in CFX, there we have to give all the properties like density, molar mass,specific heat etc, if i give the random values for density and specific heat, will it show any effect in my simulation.
Thanks in advance
Regards NVSD BABU
Old   February 23, 2009, 10:22
Default Re: material property in steady state CHT simulati
NVSD BABU
HI
Thanks in advance
Regards NVSD BABU
Old   February 24, 2009, 16:18
Yes, the values of density and Cp will affect convergence. Best to use values close to the true values as then the time scales the simulation uses will be physically sensible.
Old   February 25, 2009, 00:58
NVSD BABU
thanks Glenn
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 04:59
How to speed up the simulation of a large amount of similar steady state cases tss Main CFD Forum 4 November 5, 2010 14:36
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
CFX steady simulation gharek CFX 1 April 7, 2010 18:41
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
