Background Image in Post
Old   April 1, 2009, 05:35
Default Background Image in Post
Peter
ellevset is on a distinguished road
Hi
I am trying to overlay some simulation results onto a picture of the geometry that I have used. I choose the picture as background Image in Post, but the picture is stretched, so when I print the result the new background is very different from the original background.
Post stretches the picture in some strange way to make it fit into the viewer, has anybody else done something like this?
ellevset is offline   Reply With Quote
Old   April 1, 2009, 06:13
ehrenwirth is on a distinguished road
Hi there!
I checked your problem some minutes ago and understand your problem. The thing ist that CFX-Post stretches the background-image. You can show this effect even more if you make the 3D-Viewer-Window bigger or smaller.
Very simple suggestion:
Size your screen in CFX-Post the way you want it, make a screenshot and dont make it bigger/smaller after that. Than open a grafic-programm (i just used ms paint) and cut away everything but not the 3d-viewer-window. Now you can check how many pixels this area has, for example 573*185. Open a new painting and create a background with exactly this size. Copy your Image into this background and save the painting as background.jpg. After that, load this backgroundimage.
Hope you understand what i mean, if not just ask again!
ehrenwirth is offline   Reply With Quote
Old   April 1, 2009, 06:40
Peter
I am trying your tip now, but it seems like Post still wants to stretch the image, do you know how Post stretches? Is to fit height or width, or some other rule?
Old   April 1, 2009, 09:33
CycLone is on a distinguished road
Post will fit the height and width. When you go to print the image, specify the print dimensions to be the same as the image and you'll get the right aspect ratio, though if you are trying to get your object in a specific location it might prove difficult.
An alternative may be to create a plane using the sample option and setting the dimenstions of the plane to be that of your picture. You could then map your image onto the plane as a texture.
-CycLone
CycLone is offline   Reply With Quote
Old   April 1, 2009, 11:01
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
Maybe it is a better choice to do this within TECPLOT.
rikio is offline   Reply With Quote
CFX GUI Background Colors UnderwaterAlex CFX 2 February 12, 2008 12:09
[OpenFOAM] Background image or export to blender davy ParaView 3 September 29, 2006 06:49
How to change Fluent post background colour go FLUENT 3 September 15, 2005 10:00
A question about .eps images using CFX5.6 post Forrest CFX 6 June 18, 2004 03:24
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
