Semicircular Channel
Old   April 6, 2009, 14:55
Default Semicircular Channel
Sai
mylavarapu.1 is on a distinguished road
Hi All, I am new to CFX and I have completed a couple of tutorials. I am using CFX in workbench mode. I am trying to model a 2 mm semicircular channel and mesh it using CFX workbench. I have created the geometry using SolidWorks and imported it as a stepfile in workbench (two geometry files attached). While creating the regions (inlet and outlet) in CFX mesh mode in workbench, should I have the geometry as completely solid ? In other words, if it is not completely solid, I am not able to select the faces for specifying as inlet or outlet. In all the design modeler tutorial files, the pipe or reactor are all completely solid. What I am trying to know is if the pipe geometry (semicircular cross section) should invariably be a completely solid geometry to assign inlet and outlet faces or can I have the geometry with the semicircular channel cut extruded and still be able to select the faces for inlet and outlet. I have attached the geometry files if my question is not clear. please let me know which geometry (semicircular.jpg or semicircular1.jpg) is the right one to proceed with cfx meshing. Thanks so very much in advance,
mylavarapu.1 is offline   Reply With Quote
Old   April 6, 2009, 16:47
Michael P. Owen
michael_owen is on a distinguished road
All domains must be completely solid. You want the second option.
michael_owen is offline   Reply With Quote
Old   April 6, 2009, 18:17
Default Thank You
Sai
Hello Mike, Thank You very much !
mulltiple channel flow I.Dotsikas Main CFD Forum 2 September 23, 2010 20:49
VOF modelling open channel river flow Matthew Roberts FLUENT 6 July 31, 2009 12:52
developed channel artifact John Deas FLUENT 0 April 4, 2008 08:48
Open Channel Boundary Conditions via journal Matteo FLUENT 0 January 21, 2008 11:05
Channel Flow reference Jonas Holdeman Main CFD Forum 0 September 10, 2003 15:49
