user routine, user funcion, or fortran compile effect on the memroy? |
May 13, 2009, 14:24 |
sean strand
Dear fellows,
I have tried to run a transient model. When I set a basic transient case, it works without issue. but it makes error message by memory problem when I use user routine, user function and fortran complier(actually it is based on the HAVC sample in tutorial). Here is memory condition this is memory allocation in the case of basic transient model +--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node Real 133872.5 201.94 40.83 522939.4 807.76 Integer 232519.9 350.75 70.91 908280.7 1402.98 Character 2290.4 3.45 0.70 2236.7 3.45 Logical 51.0 0.08 0.02 199.3 0.31 Double 477.3 0.72 0.15 3728.7 5.76 This is another memroy allocation in the case using fortran compiler. +--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node Real 130494.9 196.85 39.80 509745.7 787.38 Integer 231455.7 349.14 70.59 904123.8 1396.56 Character 2289.2 3.45 0.70 2235.6 3.45 Logical 50.9 0.08 0.02 198.7 0.31 Double 475.8 0.72 0.15 3716.9 5.74 +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | *** Run-time memory allocation error *** | | Not enough free memory is currently available on the system. | | Could not allocate requested memory - exiting! | | | | | | | +--------------------------------------------------------------------+ As you can see, using fortran compiler needs samller memory to run than general transient model but it makes error... Do you guys believe that user function and user routine effect on the memory to run? How do I get out from this error? Thank you for your interest |
May 13, 2009, 18:37 |
Rep Power: 143 |
I am no expert on fortran in CFX but I suspect if you allocate memory in the fortran subroutine it will not be included in the CFX memory reporting and therefore if the routine gobbles up too much memory the solver won't know about it until it runs out of memory and crashes. Glenn Horrocks |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
CFX 10 User Routine NOT in Fortran | Andre | CFX | 14 | August 8, 2006 23:03 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
Particle Injection User Fortran Routine | Adam | CFX | 5 | December 13, 2005 03:16 |
