CFX error, "Floating point exception"
Old   July 17, 2009, 09:37
Default CFX error, "Floating point exception"
tato
moca is on a distinguished road
I am trying to model wind turbine in CFX. During the run (first iteration), i am getting the error message:
Floating Point Exception: Overflow
What's wrong with my simulation??? Thank you
moca is offline   Reply With Quote
Old   July 17, 2009, 10:42
Default its an error
T. Chourushi
Tushar@cfd is on a distinguished road
check your mesh again, this kind of error usually comes when during Pre-processing in CFX some wrong initial parameters are used....
Can you please give me more information about your work. Will see to it...
regards,
Tushar
Tushar@cfd is offline   Reply With Quote
Old   July 18, 2009, 02:03
smn
smn is on a distinguished road
hi:
i think think this error is due to the memory,,,try 64bit ansys...
smn is offline   Reply With Quote
Old   July 18, 2009, 07:41
Default smn is some what right....one of the reason i guess would be
T. Chourushi
smn is some what right....one of the reason i guess would be, you might have allocated less memory... Give it a parallel run, allocate more memory too... your problem will be solved definately....
regards..
Old   July 20, 2009, 02:18
Sorry but nobody has posted the correct answer here yet. Floating point exceptions are signs that your simulation has diverged big-time. Either the physics is wrong or the numerics are wildly unstable.
It has nothing to do with 32/64 bit.
Old   July 20, 2009, 10:05
tato
Thank you Mr. Glenn Horrocks, so what should I do?
Old   July 20, 2009, 13:10
Bharath kumar
bharath is on a distinguished road
hi,
Either your mesh quality or the physics must be wrong.please check it
bharath is offline   Reply With Quote
Old   July 20, 2009, 18:48
First you should check that the physics of your simulation are correct. It is common to fail to get convergence on something which is not physically possible.
After that is OK and you still have convergence problems then you should look into numerical reasons for the divergence. Read the documentation about "obtaining convergence". Mesh quality is one issue but there are many others.
Old   July 23, 2009, 07:58
tato
ok, thanks all
CFX error, Floating point exception Riyaz CFX 4 May 18, 2010 01:13
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 11:08
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
