CFX converge problem caused by shock waves
Old   August 10, 2009, 05:41
Default CFX converge problem caused by shock waves
littlelz is on a distinguished road
dear all,
I have got a serious convergence problem in CFX12 transition simulation.
I am doing the transition simulation on a isolated nacelle using CFX12. The mesh and the CFD model setup are ok. We can get successful results for all the test cases with various operating conditions except the cases with shock waves (in our cases, freestream mach number reaches 0.88). I have done refining the mesh on both nacelle surface and normal to it, but no success. I also follow the suggestion as in this forum (http://www.cfd-online.com/Forums/cfx...r-3d-wing.html), set max continuity loops = 2 with high res solver, however, no success at all. The general trend is no matter what I did, the simulation will converge slowly first, then diverge totally. (I monitor some critical parameters, like Cp, Cf, they can’t be converged enough).
I guess it is a converge problem caused by shock waves. I really appreciate any of your help and advice.
regards,
littlelz
littlelz is offline   Reply With Quote
Old   August 10, 2009, 06:22
Is it steady state? Assuming it is:
There are some general tips here http://www.cfd-online.com/Wiki/Ansys...gence_criteria
But in this case I would recommend concentrating on using local timescale factor. Also have you tried a solution which is subsonic, converging the solution, then slowly increasing the mach number to the desired figure? This can also help.
If that does not work then I would consider doing a full transient simulation. They tend to be the last resort when nothing else works. Slow, but the most reliable convergence.
Old   August 10, 2009, 17:47
many thanks, Glenn
always get your help and advice, thank you very much.
the tips in your link I have tried before because there is separation flow in our nacelle case, the flow can't be converged very well in steady state simulation. however, i am still using steady state simulation because we found the convergence problem caused by separation is just a local probloem, which doesn't influence the overall result. as I monitor the Cl and Cd, they converge well.
however, this time the converge problem is caused by shock wave. we have tried M=0.8, M=0.82 they are converging very well. as M reaches 0.88, it can't converge at all. so I am wondering if there is any special tips for shock wave converge problem
anyway, I will try your advice one by one.
many thanks again
littlelz
Old   August 17, 2009, 09:35
Timon is on a distinguished road
Besides using local timestepping, try enabling "high speed numerics" in compressibility control.
Timon is offline   Reply With Quote
problem in displaying surfaces in CFX haho CFX 1 July 5, 2009 19:25
CFX 11 x64 solver? problem Attesz CFX 6 June 7, 2009 08:37
Ansys Workbench (CFX) bucket problem njsavage CFX 1 April 30, 2009 09:51
Ansys CFX bucket problem njsavage Main CFD Forum 1 April 30, 2009 09:48
Workbench (CFX) bucket problem njsavage ANSYS 0 April 29, 2009 17:10
