December 7, 2009, 14:29 |
Aeroacoustic simulation in CFX
Roland Rakos
Rep Power: 17 |
I have a quite complicated flow domain. The flow is compressible, and there are some locations in the flow field where the Mach Number is large than 1. I have to investigate this flow field in terms of aeroacoustic. At the moment I have an transient result. In first approach I have defined a new quantity, the sound pressure level, and I have demonstrated the critical locations (e.g. fillets, sudden change of flowdirection) with an iso surface where the SPL is the largest. Is this approach right? Regards, Roland R. |
December 7, 2009, 16:21 |
Rep Power: 143 |
But what are you trying to do? You have not explained what you are trying to get out of the analysis.
December 8, 2009, 04:21 |
Roland Rakos
Rep Power: 17 |
Oh, sorry, you are right...
The main problem is the too large noise which develops in this part. During the function the inlet pressure expands from 11 bar to 2 bar, besides the flow field includes a lot of chamfers, edges and thin gaps. The goal of the simulation is to investigate the critical locations which can generate too large noise. |
December 8, 2009, 06:17 |
Rep Power: 143 |
You still have not been clear as to what you are trying to do. Are you trying to match a sound pressure level measurement taken from an experiment? Or are you trying to find the sources of the noise so you can reduce the aero noise of the object?
December 8, 2009, 11:14 |
Roland Rakos
Rep Power: 17 |
[QUOTE=ghorrocks;239105]You still have not been clear as to what you are trying to do. Are you trying to match a sound pressure level measurement taken from an experiment? Or are you trying to find the sources of the noise so you can reduce the aero noise of the object?[/QUOTE]
Yes yes, the second one There is not measurement so I have to rely for the CFD simulation. To tell the truth I don't have experience to the aeroacoustic therefore I tried to approach the problem first with SPL iso surfaces... |
December 8, 2009, 16:58 |
Rep Power: 143 |
I have no experience in acoustics modelling so I guess what you say makes sense. Don't forget that the propogation of the sound from the source to the observer is also important as you get reflections, superpositions and all that stuff and that means you cannot just consider the noise source in isolation.
December 8, 2009, 21:48 |
request for a project
#7 | |
srikanth
Rep Power: 16 |
i want tutorials to work upon cfx can any body help me in this matter plz |
December 9, 2009, 05:25 |
#8 | |
Roland Rakos
Rep Power: 17 |
December 11, 2009, 10:50 |
#9 |
Roland Rakos
Rep Power: 17 |
I would like to look for regions in the flow field where periodic separations can be found. I have defined monitor points in CFX Pre where I can see the pressure while the solver is running. I tried to study these points in the Post too but it is dificult due to the complicated geometry. What do you think, how can I filter these locations where periodic pressure fluctuation occurs which can be source of the noise. Regards Roland |
December 13, 2009, 05:06 |
#10 |
Rep Power: 143 |
If you have set them up as monitor point in Pre then you should have a time history for them. Yo ucan access if through solver manager. Export it as a CSV file then take it into matlab (or excel if you are desperate) and do an FFT on it to find if there are any important frequencies coming through.
December 15, 2009, 12:56 |
#11 |
Roland Rakos
Rep Power: 17 |
OK, I understand, thank you for your answer.
Roland |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
nucleate boiling simulation in CFX | Anil | CFX | 3 | August 25, 2010 14:18 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
2D simulation - ICEM meshing for CFX question | Ben Makhal | CFX | 5 | April 11, 2007 08:44 |
Simulation of turbine cascade in CFX. | Jonas Pedro Caumo | CFX | 0 | December 9, 2006 13:54 |
