how to enable turbo mode for MRF
Old   April 23, 2010, 22:57
Default how to enable turbo mode for MRF
jai
jaikrishna
jai is on a distinguished road
how can i post process the blade to blade, meridional plots in turbo mode(ref the attached pic 1 and pic 2) and how do i intialize in turo mode in cfx-pre?
note:
pic 2 shows the placement of turbine wheel inside the housing and pic 1 shows the stationary and rotating domains.
i know how to do it with single sector model (ie: SRF).
jai is offline   Reply With Quote
Old   April 26, 2010, 18:56
Have you done the turbo machinery tutorial examples? This covers how to do basic turbomachinery analysis.
Old   April 28, 2010, 00:23
jai
jaikrishna
I hope that, tutorial only explain about SRF (i.e.: with single flow passage) not entire blade passage and also with multi-component domain (ex: rotating and stationary domain).
Kindly notify me if it's available in tutorial
Old   May 4, 2010, 06:44
Susann
Suzzn is on a distinguished road
Hello jai,
when your in Post open the Turbo panel. Here you check mark the rotating domain and delete the check marks of the stationary components. After a double click on the rotating domain you can define the turbo regions (hub, shroud, blade....) and a 360° case without periodics....then initialize and you can watch blade-to-blade, meridional view and stuff. In the initialisation part left you can calculate the turbo velocity components.
hope that helps
Suzzn is offline   Reply With Quote
Old   May 4, 2010, 12:34
jai
jaikrishna
hello suzzn
thank you.
I've tried it it's working but got some warning message. i think some mistake in geometry preparation (i.e. defining correct name for the respected surface.. ex: blade, shroud..)
could you help me on this?
Old   May 4, 2010, 13:01
Susann
What do you mean with "its working" and what says the warning message exactly?
Old   May 4, 2010, 22:54
jai
jaikrishna
hi
I've attached my warning message and my geometry preparation.
Is that correct?
Old   May 5, 2010, 04:40
Susann
Huhu Jai,
I get this warning message when I define the wrong turbo regions. In your case I would define the following turbo regions:
Hub = HUB+HEATSHIELD
Shroud = SHROUD
Blade = BLADE+BLADETIP
Inlet = INTER_TURBINEOUT
Outlet = INTER_FROZEN
But I guess you already did it that way ... so I think CFX needs the hub to start directly with the blades and the INTER_TURBINEOUT and your hub is a little longer in the inlet direction. So maybe you have to split the hub region in ICEM. Maybe CFX has also problems with the heatshield at the outlet because it looks like it would create an edge on the hub.
Good Luck
Susann
Old   May 5, 2010, 10:05
jai
jaikrishna
hello sussan,
yes ... but i didn't include the "heatshield" in hub region. i'll try this one too.
DPM model in parallel batch mode Prashanth FLUENT 2 March 6, 2009 07:54
CFX in Turbo Mode Jack CFX 0 May 31, 2007 03:19
Turbo mode in CFX-5.7/10 kiran choudar CFX 2 July 5, 2006 03:10
Stator tip gap at hub in turbogrid /CFX post turbo Adam CFX 1 May 29, 2006 04:47
Batch mode swapnil CFX 5 November 23, 2002 09:38
