May 6, 2010, 08:29 |
non constant material properties
Di Varano
Hello all,
I 'm relatively new to ANSYS CFX, so maybe it's a silly thing but I was not able to find anything related to the following problem: How can I insert a table of values for different conductivities at different temperatures? Do I have to use CEL syntax and if yes where can I find any example and manual? I can toggle only value option under transfer properties, unless I don't define a table from the beginning. Thank you very much , Igor |
May 6, 2010, 21:12 |
Rep Power: 143 |
This is all covered in the tutorials. Make a 1D interpolation function (or define your CEL expression somehow) and then refer to that CEL expression in the material property.
cht solid properties |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Chemical properties that are used in Fluent | kimej | FLUENT | 4 | August 19, 2011 11:29 |
How to add more material properties | sarahsun | CFX | 1 | October 27, 2009 07:27 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
