[CFXv11]importing CFX convection into WB
Old   June 13, 2010, 10:00
Default [CFXv11]importing CFX convection into WB
mactech001 is on a distinguished road
Dear all,
i'm encountering another problem while importing CFX convection into WBv11.
please see attached picture.
Figure 1: areas in the cooling channel on the housing that is interfacing with fluid. Notice the areas of the coolant ports are selected
Figure 2: areas defined as cooling channel on housing interfacing with fluid in CFX-Post. Note that, the default interface DID NOT select the coolant port areas.
however, the simulation in WB completed smoothly. i would expect WB to pop out a message claiming that importing will not be possible, because the interface definitions are not entirely correct and transfering data between the nodes will not be possible.
but why has WB completed the simulation even though the interfaces are not matching?
Any thoughts will be helpful. Because, now when i re-do another calculation with a different fluid flowrate, WB is complaining that transfering data between nodes is not successful.
Please help.
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
Old   June 14, 2010, 18:37
If faces do not match then the GGI assumes they are not in contact. Then it applies slip/adiabatic walls on those faces. You can make them no slip/heat transfer walls in the options.
You usually have to fix the default selection of interfaces as the default guess is wrong. It is tedious but necessary.
natural convection in ANSYS CFX 10 cryo man ANSYS 0 June 9, 2009 07:53
natural convection problem in cfx NVSD BABU CFX 7 November 13, 2008 10:56
Natural convection problem in CFX 11 Willy CFX 2 May 23, 2008 23:12
Thermocapillary/Marangoni Convection in CFX Seamus CFX 6 May 30, 2007 20:38
CFX to model convection cells FER CFX 4 December 13, 2006 00:57
