CFX12 crashes if trying to open a *.def File
Old   September 25, 2009, 06:02
Default CFX12 crashes if trying to open a *.def File
peterputer1 is on a distinguished road
Hej,
i ve a problem with CFX12 Pre. I just installed it and tried to open an old definition file. Then i get the following error msg:
Severe Error
SEVERE
Operation failed. (System exception: Token name resolves to parent type: FLUID)
WARNING
Unknown quantity type: Relative Molecular Mass
Afterwards CFX Pre just crashs. I opened several other definition files without any problem (still the warning about the unknown quantity type was there, but at least it runs), so CFX Pre12 is working, but just not for the definition file im currently working with :/
Anybody has some hints?
Regards
peterputer1 is offline   Reply With Quote
Old   September 25, 2009, 06:51
First import the mesh (and only the mesh) into CFX-Pre. The use cfx5cmds to extract the CCL from the old def file, then import that CCL into CFX-Pre.
Old   November 6, 2009, 06:10
Hej,
it is not allowed in CFX-Pre 12 to call a Domain "FLUID" anymore with capital letters, if i rename it to Fluid it works fine.
Regards
Old   November 7, 2009, 05:35
Wow, that's a weird error. Can you report it to CFX Support and hopefully they can fix it for the next release?
Old   July 28, 2010, 05:12
martinD is on a distinguished road
I have the same problem with CFX-post. The error is shown when the program is started, before any *.res file is loaded.
martinD is offline   Reply With Quote
Old   July 28, 2010, 06:05
Matthias Voß
mvoss is on a distinguished road
hi,
try to import the def-file not load it with CFX-Pre.
I think it is because of the newer naming in the materials which comes with CFX12.
neewbie
mvoss is offline   Reply With Quote
Old   July 28, 2010, 07:05
hi,
I have tried, but it does not work. actually i don not realy know what you mean. Import option in post supports only csv files.
martin
Old   July 28, 2010, 07:10
Matthias Voß
i suppose you want to open some def. res. file from cfx11, right?
if it´s like that, you have to import the files into the WB instead of opening them in the appropriate program. saying so, because i know it from this missing molar mass entry from your first post.
neewbie
Old   July 28, 2010, 07:28
Yes, you are right. actually I have created the simulation in CFX-pre-v11, usually we are using solver v11 and also post, but in this case I have used another computer with version 12.
That probably means that I have to create another .def file with import and than restart simulation.
martin
Old   July 28, 2010, 07:32
Matthias Voß
i guess that WB can handle "old" datasets, that would be the workaround.
or
maybe you can restart from the res. and only doing one iteration ending up in an "new" res file....
neewbie
Old   July 28, 2010, 07:43
thanks,
martin
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
