August 12, 2010, 20:54 |
Laminar Model
Danillo Cafaldo dos Reis
I want to know if when I set the turbulence model to laminar CFX will solve exactly the Navier Stokes Equations. CFX user guide says: "Laminar flow is governed by the unsteady Navier-Stokes equation. The laminar option does not apply a turbulence model to the simulation and is only appropriate if the flow is laminar" So, the fact thar it doesn't apply a turbulence model means that the equation that is solved is the NSE? It seems true, but could be false I think. What I want to simulate is a Mixing Layer. I will start with a tangent hyperbolic profile and analyse its development until it gets turbulent, so I have a laminar flow. I want to know what CFX does solve for this case. Thanks |
August 13, 2010, 06:13 |
Rep Power: 143 |
Sounds like you need to read a basic CFD textbook. The laminar model is the Navier Stokes Equations, when you apply a turbulence model you then are talking about the Reynolds (or Fauve) averaged Navier Stokes equations. I recommend you read a CFD textbook to understand what the previous sentence is saying.
If your flow is laminar or just getting transitional a laminar model is probably OK. Sometimes you need the turbulence transition model, depends on the case. CFX supports both approaches. |
August 13, 2010, 08:24 |
Thank you ghorrocks.
I'm starting my CFD study now I have a lot to learn. I asked this because one told me that in CFX solver the laminar model was not implemented with the NSE but also with a RANS with such parameters that approximate the NSE. Theoretically I know that laminar means NSE, without turbulence, but me question was how do the solver see this. Regards |
August 13, 2010, 15:28 |
Joshua Counsil
Off-topic, but I thought I'd let you know you have a very cool name, Mr. dos Reis.
August 14, 2010, 07:36 |
#5 | |
Rep Power: 143 |
August 16, 2010, 10:43 |
Ok Ghorrocks.
Thank you very much for your answer. Thanks Josh. |
Laminar flow and roughness in fluent?? | 1000sh | FLUENT | 0 | April 16, 2010 14:42 |
Turbulence and Laminar model for empty narrow chan | KKLAU | FLUENT | 5 | October 18, 2004 17:36 |
Laminar finite rate combustion model | Shankar | FLUENT | 3 | June 24, 2004 15:40 |
Pre-mixed combustion- Laminar finite rate model | Shankar | FLUENT | 8 | March 31, 2004 05:18 |
how to model transition laminar to turbulent? | james | Main CFD Forum | 0 | October 1, 2003 03:16 |
