Moving Mesh in CFX
Old   October 19, 2010, 04:06
Default Moving Mesh in CFX
Greg Hylands
GHylands is on a distinguished road
I am modelling a sloshing flow in CFX V.12 to compare with experimental data. Is there any way of importing the measured displacemnet from the experimental rig into CFX to control the movement of the mesh?
Thanks in advance for your responses,
Greg
GHylands is offline   Reply With Quote
Old   October 19, 2010, 12:00
stumpy is on a distinguished road
Is the rig a rigid body, so you just have displacement versus time? If so, create a 1D interpolation function then instead of manually entering the data point you can right-click to import data from a file. Next you'll want to define your entire moving domain as a subdomain, then set the motion of the subdomain to use the 1D interpolation function.
stumpy is offline   Reply With Quote
Old   October 20, 2010, 05:32
Greg Hylands
Thank's for your advise. You are correct to assume that the rig is a rigid body and that the displacement is simply time dependant. I'll give this a go and let you know the outcome.
Many Thanks,
Greg
cfx, experimental, mesh, sloshing
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 08:59
cfx mesh problem... mactech001 ANSYS Meshing & Geometry 0 November 5, 2009 02:19
Turbulence model for CFX moving mesh songxguan CFX 7 June 28, 2009 21:05
Moving and deforming mesh paolo FLUENT 0 June 19, 2003 08:12
