Not stall
Old   December 27, 2010, 15:05
Default Not stall
thais_b is on a distinguished road
Hi!
I searched in the entire forum and did not find a precisely answer so i am posting my problem (I'm new in CFX).
I'm working with 2D simulation of NACA 0012, with a mesh (unstructured) designed in ICEM. My Cl values seems very good until the stall angle.
The cl gets higher and higher while the AOA attack increases. I can see in the post that the separation occured with a streamline, but the cl remains increasing.
I used the SST isothermic model.
Thanks!
thais_b is offline   Reply With Quote
Old   December 28, 2010, 04:05
Getting accurate models after stall is difficult. You probably won't be able to do it using SST, you will probably need a very careful validated LES/SAS/DES model.
Old   December 28, 2010, 18:56
Thanks for your answer!
But, what you mean with careful validated ?
I tried to use these models and the cl values get close but they remain higher. Do you think it can be related only to my mesh quality? I checked in ICEM and the transition near the airfoil wasn't abrupt, and the quality was good.
Thanks again.
Old   December 29, 2010, 05:44
Validated means you have ensured the mesh, convergence, time step and other numerical parameters are correctly set to give the required level of accuracy.
The LES/SAS/DES models will require different time steps and meshes to the RANS models.
stall simulation Kevin Lamers FloEFD, FloWorks & FloTHERM 1 January 29, 2009 06:24
Airfoil at stall angle cfd_newbie FLUENT 10 February 5, 2008 11:33
static stall atrh Main CFD Forum 1 March 9, 2004 06:07
Looking for experiments in dynamic stall Anton Lyaskin Main CFD Forum 0 February 10, 2003 03:57
stall yin Main CFD Forum 1 May 10, 2000 03:03
