March 9, 2011, 03:53 |
symmetry boundary condition
iswadi
Rep Power: 16 |
i have some problem regarding on symmetrical boundary condition.
please refer to the picture attached. i have setup a symmetrical boundary condition for the same model. but i have noticed that, the indicators (red arrow) for symmetrical boundary condition does not match. As you can see here, the red arrow for correct boundary setup was distributed evenly at edge of symmetry plane. However this does not happen in the faulty model.However, i try to run the fault model but the solver said there was no data solved. is it because of this symmetry condition? Do anybody have any experience in this situation? what should i do to correct this situation? |
March 9, 2011, 18:50 |
Rep Power: 143 |
I suspect you have a meshing problem. Check your mesh.
March 12, 2011, 19:28 |
iswadi
Rep Power: 16 |
yes. i already encounter the problem in this situation. it is because of meshing. i have put a body of influence (BOI) mesh behind the wing. if i removed the BOI mesh then the symmetry is back to normal. maybe anybody can answer to this situation?
March 13, 2011, 05:40 |
Rep Power: 143 |
I bet your mesh is terrible. So the weird marker placement is because of a weird mesh. That is why I suggested you have a mesh problem.
Have you looked at the mesh on the symmetry plane? |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 05:05 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
Mixed/Robin boundary condition | aaev | OpenFOAM Bugs | 2 | December 15, 2011 14:03 |
Slip boundary condition what is inside | normunds | OpenFOAM Running, Solving & CFD | 2 | June 4, 2007 06:45 |
Regarding SYMMETRY boundary condition | Praveen Athanki | FLUENT | 0 | March 27, 2000 13:30 |
