Boundary Conditions while using Symmetry planes
Old   March 17, 2011, 19:43
Default Boundary Conditions while using Symmetry planes
Gary
garychem is on a distinguished road
Hi all,
I am using symmetry planes in the geometry. From what I understand, if I'm designing a quarter section of the equipment, the inlet mass flow rates will also be quarter of that of the equipment as a whole. However, will the same condition be applied to the outlet pressure? I am using an outlet pressure of 17 kPa (outlet pressure for the whole equipment), so should I use 1/4th the outlet pressure for the quarter section?
Thanks.
garychem is offline   Reply With Quote
Old   March 18, 2011, 02:37
Lance
Lance is on a distinguished road
Pressure is an intensive property and does not depend on the system size, unlike mass which is a extensive property.
So, no, you should set 17 kPa at your outlet.
http://en.wikipedia.org/wiki/Intensi...ive_properties
Lance is offline   Reply With Quote
Old   March 18, 2011, 19:22
Gary
Thanks a lot for the information.
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry Boundary Conditions club68512 FLOW-3D 7 August 30, 2012 09:05
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
wall and symmetry boundary conditions malik FLUENT 2 April 22, 2008 07:48
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
