how to calculat the pressure coefficient in ansys |
October 30, 2006, 12:53 |
Hi, can anyone tell me how to plot and calculate the pressure coefficient around a body in CFX-post so that in every defined location the Cp plot will be created?Thanks
October 30, 2006, 14:03 |
Re: how to calculat the pressure coefficient in an
Write a CEL expression for Cp, then create a new variable with your expression. Your variable can be plotted as any other variable.
-Robin |
October 31, 2006, 09:07 |
thanks Robine, I try
March 2, 2010, 09:28 |
Rep Power: 17 |
I also want to plot Cp along a Line. Thus I have written the following equation: (Pressure-(Pressure@Inlet))/(0.5*Density@Inlet*Velocity@Inlet^2) But i get this odd error Message: "...The following unrecognised names were referenced: Density, Pressure, Velocity." Altough I got these Names from the "right-click-insert-menu" Anybody knows where the problem is? Thanks! |
March 2, 2010, 16:58 |
Rep Power: 143 |
Have a look in the CFX documentation, in the reference guide, for CEL expressions. This will give you the variable names. You have simply not used the correct variable names.
July 27, 2010, 03:05 |
Nick
Rep Power: 17 |
Hi camoesas
Could you please tell me if you were able to get the above CEL expression to work. I am facing the same problem. Your help will be very much appreciated. |
July 27, 2010, 07:22 |
Rep Power: 143 |
The errors camoesas made are trivial - look in the documentation and you will work it out. For instance he should replace "Density@Inlet" with massFlowAve(Density)@Inlet, and other simple changes.
April 12, 2011, 02:40 |
help on the CEL plz
#9 | |
hanna
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
Problem in Result of the pressure coefficient | Ken Choi | Main CFD Forum | 2 | March 15, 1999 04:15 |
