pressure transient term?
Old   April 17, 2011, 22:08
Default pressure transient term?
Romek is on a distinguished road
can someone explain the pressure transient term to me (which can be checked when thermal energy model is selected)? or give me a link? i searched for some info but didnt find an explanation. also the ansys documentary which normally has everything i need didnt provide a description.
i am trying to simulate oil flow through bearings. I am using the SST model (ansys cfx 13). But i dont know if i need the pressure transient term or not.
thanks!
Romek is offline   Reply With Quote
Old   April 19, 2011, 13:03
siw
Stuart
siw will become famous soon enough
I would also like to know about this term.
Couldn't find any option to check it on/off, though. Where would that be exactly?
siw is offline   Reply With Quote
Old   April 19, 2011, 20:55
In CFX-Pre...
Set Analysis Mode to transient.
In the Fluid-Models Tab of a Domain -> Set Heat Transfer to Thermal Energy -> Then it should appear directly under this option.
What's strange is when you turn the pressure transient term on a new box appears where you can turn it on again. Does that make sense?!
Using Ansys 13.0...
Just noticed with pressure transient term on (both options on), my system pressure is almost the same but the temperature-change in the system changes significantly.
Old   April 19, 2011, 21:14
The pressure transient term of which model?
Old   April 19, 2011, 21:19
thermal energy heat transfer model
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 17:19
how to output the static pressure of transient Fred FLUENT 0 January 11, 2006 02:27
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
