Question from help of CFX
Like Tree1Likes
  • 1 Post By mauricio
Old   August 20, 2011, 10:59
Default Question from help of CFX
Alireza Safikhani
Hamilton is on a distinguished road
Hi friends,
In the help of CFX at the Gas-Solid modeling part is stated that water should be selected as continuous fluid and sand should be selected as " Dispersed Fluid " however sand is solid and not fluid , what is the reason ? should we really select sand as a fluid ?
regards
Hamilton is offline   Reply With Quote
Old   August 20, 2011, 14:28
Mauricio Labarca
mauricio is on a distinguished road
I'd model it as dispersed solid. You'll have to define the density and properties of the sand material you're going to use. I believe There's actually a tutorial of a dispersed solid and a continuous fluid around it i think.
mauricio is offline   Reply With Quote
Old   August 20, 2011, 15:28
Alireza Safikhani
Thank you very much so you think it is wrong ? and it should be dispersed solid ?
Old   August 20, 2011, 20:28
Mauricio Labarca
It's not technically wrong for a specific case, check this out from the documentation on cfx's multiphase modelling :
It is possible to model the motion of a large number of solid particles in a gas or a liquid as an Eulerian-Eulerian two phase flow. Examples occur in pneumatic conveying, sedimentation in rivers, and fluidized beds.
For example, the two phases may be Water, the continuous fluid (Continuous Fluid), and Sand, the dispersed fluid (Dispersed Fluid).
In such problems, you should assign the solid phase a small insignificant molecular viscosity. This is permissible, as the physics are dominated by inter-phase drag and turbulence effects. The solid phase should be assigned free slip boundary conditions at walls. If viscosity is not set, the solid material will not be available for selection in the Fluids and Particle Definitions... list on the Basic Settings tab of the Domains details view in CFX-Pre
That would be the case where sand could be treated as a fluid. for other cases, you should set the sand as a particle transport solid, for an example check the tutorial of "Flow through a butterfly valve".
ngoc_tran_bao likes this.
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
CFX Post question - creating a reference vector Martin CFX 2 February 16, 2009 23:13
One question about the cfx 5 best practices John CFX 3 August 18, 2005 18:39
Question about the shock wave in CFX software nucharin Main CFD Forum 1 January 25, 2005 08:26
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
