Transient simulation (Problem with massflow and Pressure) |
Christian F
Rep Power: 15 ![]() |
Hello everybody,
i am simulating a rotary piston engine. The Simulation is working but the problem is the following: At the beginning the pressure inside of the cylinder is 0 bar (reference pressure is 1 bar). At the inlet the pressure is 3 bar. While the piston is moving, air is flowing from the intlet in the cylinder and the pressure rises. When the pressure in the cylinder is reaching the 3 bars (The maximum pressure) the pressure an massflow increase from the inlet into the cylinder should go down, but i am reaching even 3.5 bars until the massflow goes down. As you can see in the diagram the pressure for a certain time step is not changing anymore after some iteration steps. So i am only reaching the 3 bars after some timesteps (which is of course different to the reality). In a steady state analysis for a certain Piston positon i am reaching the 3 bars after about 30 iteration steps. So what do i have to do to get the simulation closer to the reality? Thanks. |
Christian F
I am sorry i forgot to upload the picture
Rep Power: 14 ![]() |
How big is the time step used and how did you set up your inlet boundary(pressure and mass flow)?
Christian F
Inlet: -Total Pressure (3 bar)
- Total Temp 25C° Timestep: -1/60000 s (1.666e-5 s) -> Engine is rotating with 10000 rpm so in one timestep the piston is moving 1° |
Rep Power: 143 ![]() ![]() ![]() ![]() |
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
You would need to include more details if you want us to be more specific. |
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls | david39 | OpenFOAM Running, Solving & CFD | 6 | January 18, 2011 11:49 |
turbulent simulation pressure control valve | SimonH. | OpenFOAM | 9 | September 23, 2009 09:41 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
Pressure Drop and Massflow rate issue | M | Siemens | 4 | February 13, 2008 09:12 |
pressure problem in reservoir | prem | FLUENT | 0 | April 4, 2006 12:47 |
