user defined function in Transient Structural for FSI problem
Old   November 23, 2011, 07:41
Default user defined function in Transient Structural for FSI problem
omid
omidiut is on a distinguished road
Hi all
I'm trying to simulate 2-way FSI problem.
Can i define an user function to access to the tension of solid domain?
in my problem i need to set tension of solid to zero after each coupling time step. i can do it by Abaqus but a don't know how can do it by ansys workbench.
Best regards.
omidiut is offline   Reply With Quote
Old   November 24, 2011, 09:45
stumpy is on a distinguished road
Do you mean you want to reset the stress/displacements to zero? What's the big picture here? Why do you want to do that?
stumpy is offline   Reply With Quote
Old   December 2, 2011, 07:23
omid
Thanks for reply Stumpy
In this problem, in the solid body in each coupling step, any energy will not store. in other hand the displacement of solid body in each coupling step most be independent of the stress store in it from last coupling step. i like to simulate the displacement of solid part due to pressure distribution in each coupling step.
Best regards.
Old   December 2, 2011, 16:51
If I understand correctly, then you want the structural solution at each coupling step to be independent of the solution history. So like a series of static structural solutions based on your transient CFD results. Is that correct? This must be a 1-way analysis then? If so, then just turn off Time Integration in Mechanical.
Old   December 3, 2011, 02:32
omid
yes I want the structural solution at each coupling step to be independent of the solution history. But in each coupling step the displacement of solid most calculated and transfer to fluid part, like 2-way FSi. Is that true with just urn off Time Integration in Mechanical i can do it?
Best regards
Old   December 5, 2011, 11:19
Yes, if you turn off Time Integration then you get a steady-state structural solution at each coupling step (and at each coupling iteration) and the displacements are still passed to the CFD side.
User Defined function for scalar gradient caculation with Star ccm+ V4 coolio STAR-CCM+ 4 August 11, 2023 05:38
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
User Defined Function for convection coefficient ereiss FLUENT 1 July 8, 2004 16:10
Help: user defined function alice FLUENT 3 December 13, 2000 00:10
