April 15, 2019, 07:58 |
Lift Force
Isabella Fernanda
Dear Colleagues,
I'm a Chemical Engineer(ing) student and I'm simulating a drone in CFX. I need to calculate lift force of this drone. I'm currently using this tutorial as a guide to my calcutations: https://www.youtube.com/watch?v=_6nLbNQAcIk Basically, the boundaries are "opening" type and "force_z@drone" is used to obtain the lift force. Is this the correct formula/method? If not, what should I use? Thanks |
April 15, 2019, 18:50 |
Rep Power: 143 |
Providing the lift force is defined in the z direction then that is the correct CEL expression to use. Also the boundary surface named "drone" would have to be the entire outer surface of the drone.
April 15, 2019, 21:38 |
Isabella Fernanda
Thank you for your reply!
drone, force, lift |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Saffman Lift Force: confused | CFD_MAN | FLUENT | 5 | September 9, 2010 04:51 |
Urgently Need the code of Lift force and VM force | Kai Yan | Main CFD Forum | 0 | July 16, 2008 07:07 |
Saffman Lift Force | CFD MAN | Main CFD Forum | 0 | November 26, 2002 18:26 |
