Error msg: In Analysis 'Flow Analysis1 : No domains have been defined |
February 4, 2012, 23:14 |
mohamed khedr emam
I am try two suggested method
1- Define firstly a Domain and comeback to Cfx setup --->the same massage appears again 2-also Iam try to import my mesh externally but another error massage appear Please help |
February 5, 2012, 06:59 |
Could you please tell us some more information about your approach? For example, did you use ANSYS Meshing to mesh your geometry?
February 5, 2012, 08:01 |
mohamed khedr emam
I am built my geometry (wind Turbine blade) in DesignModeler(Ansys12) then meshed it in Ansys12 meshing then I sholud open Cfx setup to set the B.c and I.c but didn't find the geometry (Error appear here)
February 5, 2012, 13:52 |
Is your geometry 2D or 3D?
What icon is shown next to the mesher box in Workbench? Is it a green tick? |
February 20, 2012, 08:17 |
mohamed khedr emam
I discovered that i should work with Ansys fluent not CFX , thanks any way
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
Compressible flow analysis | Sonu | Siemens | 3 | December 5, 2007 07:25 |
User defined function of mass flow rate | Eric | FLUENT | 1 | April 22, 2005 18:15 |
Coolant flow analysis - IC engine | Frank | FLUENT | 2 | May 19, 2002 15:59 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
