February 5, 2012, 13:47 |
problem in solver
Shashwat
Rep Power: 14 |
please find the attached one
i am facing problem while run the settings can you please help me regards shashwat |
February 5, 2012, 17:20 |
Rep Power: 143 |
Seems pretty obvious to me. You need more memory, or run it distributed parallel to share the load over several machines. Otherwise remesh with a smaller mesh.
February 5, 2012, 22:27 |
Shashwat
Rep Power: 14 |
hi
smaller mesh means? do you mean number of elements and number of nodes ? my current elements are 256413 nodes 449588 |
February 6, 2012, 01:28 |
Shashwat
Rep Power: 14 |
hi
please find the error I would like to explain my problem fluid is flowing in a multilayer porous medium which has different porosity and different permeability. I have created multiple layer and created domain. i did interface fluid porous, porous porous, porous porous and so on . the layer has 2micro meter , 10 micrometer, 200 micro meter and so on Please help me where did i made mistake? thank you shashwat |
February 6, 2012, 19:09 |
Rep Power: 143 |
Rather than specifying this as different sub domains with different permiabilities it might be better to define the porosity and permeability as a function of location and use a single sub domain with variable porosity and permeability.
February 6, 2012, 23:19 |
Shashwat
Rep Power: 14 |
hi
I got your idea can you please give a start or hint how to do it ? |
February 6, 2012, 23:27 |
Shashwat
Rep Power: 14 |
hi
how to specify different porosity and permeability in a different layers of region Please help to start my project Thank you Regards Govind |
February 6, 2012, 23:54 |
Shashwat
Rep Power: 14 |
hi
do you mean in the designmodeler , I have to create two solids, one fluid region part and other is porous region part.In cfx pre I have to specify different porocity and different permeabilty in a different layers( region) of the porous part . Am I correct? Regards Shashwat |
February 7, 2012, 01:08 |
#9 |
Shashwat
Rep Power: 14 |
Hi
How to split the single zone into multiple layers in cfx pre, for applying different porosity and different permeability Thanks Regards Shashwat |
February 7, 2012, 16:21 |
#10 |
Rep Power: 143 |
Define your porosity and permeability as a CEL function, either an expression or an interpolation function. Have a look at the tutorials for how to do this. The free surface flow over a bump tutorial shows how to do this when they set up the inlet boundary condition.
[swak4Foam] Problem using swak4Foam in a modiefied solver | bastil | OpenFOAM Community Contributions | 13 | April 18, 2020 15:17 |
mesh.update problem in a new FSI solver | ICL | OpenFOAM | 0 | October 8, 2011 14:16 |
Compilation problem after modifying a solver. | PetSul | OpenFOAM Running, Solving & CFD | 2 | October 1, 2009 17:28 |
patching problem unsteady solver | yellow-stuff | Main CFD Forum | 0 | September 25, 2009 01:26 |
Coupled solver energy equation problem | lucioantonio | FLUENT | 0 | April 3, 2009 10:21 |
