Continue the solution from where the license is timed out
Old   March 11, 2012, 17:21
Question Continue the solution from where the license is timed out
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear all,
I am doing unsteady simulations. Sometimes, because of some network problems in our university, Ansys CFX license is missed and I have to start the simulation from the beginning. Is there any way to continue the solution from where the license is timed out?
I mean, Let's say my total simulation time is 2s and the Ansys CFX license missed at time 1s, is it possible to use the results of time 1s and continue the simulation.
Thank you
AshtonJ
ashtonJ is offline   Reply With Quote
Old   March 11, 2012, 21:08
Erik
evcelica is on a distinguished road
If you are doing a transient run, I'm sure you are writing results files every so often, correct? When you define the new run, start from initial conditions, and check the box that says "initial values specification" and browse to the last results file you wrote before you lost the license. Your simulation will then start from the results file you just chose.
evcelica is offline   Reply With Quote
Old   March 11, 2012, 21:22
Ashkan Javadzadegan
Thank you very much. In fact, I don't know the results is writing every time step, the only thing I do is to define transient results in output control in CFX-Pre and specify the variables I need and write them just in last second of the simulation run.
In this case, please let me know if I can use your mentioned method.
Kind regards,
AshtonJ
Old   March 12, 2012, 19:13
Erik
You can start you simulation from any results files you have written. So if you haven't written results yet then you won't be able to start from them. I always write all results, so I don't know anything about if you only write certain results to the output file.
I usually just go to "Output Control" in pre and choose to write results with a simulation time step of x seconds.
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
ANSYS License Error vincentryan.s ANSYS 0 June 7, 2011 15:31
Transient, initial variables from a previous solution nakor FloEFD, FloWorks & FloTHERM 0 April 22, 2011 04:34
new license key antonio CFX 2 December 2, 2010 04:57
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
