Home > Forums > Software User Forums > COMSOL
Low reynolds number airfoils simulation - COMSOL Multiphysics
Old   November 13, 2014, 06:15
Default Low reynolds number airfoils simulation - COMSOL Multiphysics
Djone Viana
DjoneViana is on a distinguished road
Hello!
I'm working on a simulation of low reynolds number airfoils in software COMSOL Multiphysics 4.3, using the k-e turbulence model and extra-fine triangular mesh.
I have three basic questions that I could not solve yet. I know that in other simulation software these values is "ready", like in CFX. The questions are:
- How can I get the value of "y+" in COMSOL?
- How can I get the characteristic graphs cl and cd in this software?
- There is some method in COMSOL to analyze the drag and lift through the pressure and velocity fields? Since this is the only result that I arrived.
Thank you in advance.
P.S.: Is the first time that I work with numerical simulation in this software, and it's really important because my "term paper" is based on this simulation.
DjoneViana is offline   Reply With Quote
Old   November 14, 2014, 03:28
adrin
adrin is on a distinguished road
I don't know much about COMSOL, but: What does low mean? What's the Reynolds number? Is a turbulence model even necessary? In either case, k-e is the wrong model for "low Reynolds number" turbulent flow
Adrin
adrin is offline   Reply With Quote
Old   November 14, 2014, 06:42
Djone Viana
Thanks for answer adrin...
The reynolds number is Re = 4,73x10^5 in this case, and the turbulence model is necessary cause we working with "critical airfoils" (S1223 and E423), the laminar flow don't run correctly, show errors about non convergence points, etc.
As said, I don't have much experience with numerical simulation, and applied the k-e model taking as a basis other papers of undergraduate and master's. The COMSOL have two other options: K-omega and Spallart Almaras models.
Have you any suggestion about it?
And about the obtaining of cl and cd, an idea?
Thanks and regards.
Old   November 15, 2014, 07:55
truffaldino's Avatar
truffaldino is on a distinguished road
You will not get accurate results with ordinary k-omega or sa since in these models flow will be turbulent everywhere. They cannot feel laminar part of the flow and transitional region.
truffaldino is offline   Reply With Quote
Old   November 15, 2014, 08:29
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Re=470000 doesn't seem "low" to me…
lovecraft22 is offline   Reply With Quote
Old   November 19, 2014, 18:05
Simbelmynė's Avatar
Simbelmynė is on a distinguished road
Originally Posted by DjoneViana View Post
Hello!
I am not working with COMSOL myself but I have people in my group doing so from time to time. I have seen them perform all of the above questions, so either it exists in the code or they use their own functions. You can easily define your own functions/variables in COMSOL. For instance, drag can be found by integrating the appropriate function of drag across the boundary of interest.
This might help: www.comsol.com/showroom/downlo...e/models.mph.cylinder_flow.pdf
Simbelmynė is offline   Reply With Quote
Old   November 19, 2014, 18:20
Simbelmynė's Avatar
Re=1e9 might be low and Re=1e3 might be high. Without knowing the system it is impossible to tell. Comparing to pipe flow or flow over a cylinder I would agree it doesn't seem low. I have seen many airfoil calculations/experiments with substantially higher Re though.
airfoil, comsol, lift and drag
low reynolds number turbulence model in FLUENT shubham jain FLUENT 1 March 1, 2014 07:49
Low Reynolds number question wildfire230 OpenFOAM Running, Solving & CFD 7 December 13, 2013 04:34
low reynolds number models in Fluent doug Main CFD Forum 6 August 4, 2012 14:39
Low Reynolds Number Instability in icoFoam - Cavity Case kmooney OpenFOAM Running, Solving & CFD 2 October 8, 2009 14:09
Low Reynolds number K-Omega modeling Athar Zaidi Main CFD Forum 0 October 31, 1999 13:59
