Home > Forums > Software User Forums > COMSOL
How can I define my own set of PDE & ODE in COMSOL
Old   June 2, 2008, 13:58
Default How can I define my own set of PDE & ODE in COMSOL
bhushan
I want to define my own set of PDE and ODE on some domains in COMSOL. Actually, i want to use some predefined equations and some my own equations on certain domains. How can I do that?
Old   June 5, 2008, 03:35
Default Re: How can I define my own set of PDE & ODE in CO
Magnus Ringh
This is one of the key features in COMSOL Multiphysics: the ability to define your own PDEs as well as ODEs and other "global equations" (algebraic equations, etc.) for equation-based modeling as a complement to the predefined interfaces for fluid flow, diffusion, heat transfer, structural analysis, electromagnetics, etc.
There are three formulations of PDEs that you can use:
- Coefficient form, for linear or almost linear PDEs
- General form, for general nonlinear PDEs
- Weak form, a variational formulation using test functions
The COMSOL Multiphysics Model Library contains a whole section called Equation-Based Models, which is devoted to models that solve custom PDEs using the above formulations. There are also several model examples of how to incorporate ODEs, algebraic equations, etc. Note, though, that such equations are normally space independent and are not defined on a domain.
Hope this helps,
Magnus Ringh COMSOL
Using Level Set Method to Model Evaporation in COMSOL jhoffma4 COMSOL 0 September 11, 2022 16:05
udf for source term in UDS equation dkjknobel Fluent UDF and Scheme Programming 12 August 19, 2019 07:57
Remeshing for Rotation in CFX via ICEMCFD gera CFX 3 September 23, 2017 12:29
How to define cell set by using treshold erzdemir STAR-CCM+ 1 July 26, 2016 01:47
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
