Home > Forums > Software User Forums > CONVERGE
Significance of brackets [] in boundary.in
Like Tree1Likes
  • 1 Post By ksrivast
Old   February 16, 2016, 10:47
Default Significance of brackets [] in boundary.in
Chris Pounds
Pndsc is on a distinguished road
I'm scripting a system for automatically changing BC's in simulation runs. Is there a particular significance to variables that are specified with brackets around them, or is it just to denote that they are an Inflow?
Pndsc is offline   Reply With Quote
Old   February 16, 2016, 12:49
ywang89's Avatar
Yunliang Wang
ywang89 is on a distinguished road
Hi Chris,
The brackets [ ] in boundary.in imply that the pressure is total pressure. Otherwise it is static pressure. This is usually for the INFLOW BC. When the pressure BC is set to total pressure, the temperature BC at the INFLOW is set to total temperature automatically. Therefore, you don't need to set the total temperature BC at the INFLOW.
Thanks,
Yunliang
Yunliang Wang
Applications Manager
CONVERGECFD
ywang89 is offline   Reply With Quote
Old   January 14, 2019, 11:53
mohsin
mohsinmkhan is on a distinguished road
Originally Posted by ywang89 View Post
Hi Chris,
Thanks,
Yunliang
Sir, I am having one doubt regarding that, for inflow boundary : If we check the total pressure and give pressure.in file instead of mentioning pressure value, we cannot give mass flow value under velocity boundary condition. Then in this case how can we decide or know at what flow rate inflow is happening and how can we vary the flow rate in such case where we are give pressure rate curve..??
mohsinmkhan is offline   Reply With Quote
Old   January 16, 2019, 18:03
ksrivast's Avatar
Kislaya Srivastava
ksrivast is on a distinguished road
Greetings,
For subsonic flows, you can have a DIRICHLET/specified boundary condition for either the pressure or the velocity. The other should be Neumann. MASS FLOW is a special dirichlet condition for velocity, and thus cannot be provided along with a pressure profile for your INFLOW boundary.
If you have specified a pressure profile for the INFLOW, you can always obtain the corresponding mass flow rates through the INFLOW in mass_avg_flow.out. Considering a simple example of flow through straight pipe, this flow rate will vary if either the pressure at INFLOW or that at OUTFLOW is varied.
Hope this helps,
Sincerely,
mohsinmkhan likes this.
Kislaya Srivastava
Principal Research Engineer | Applications
CONVERGECFD
ksrivast is offline   Reply With Quote
How to plot a forces.dat file (with all the brackets)? CapSizer OpenFOAM Post-Processing 16 December 17, 2019 08:26
physical significance of.... vijesh Main CFD Forum 7 August 13, 2007 03:18
What is the significance of... Sharad Dugad FLUENT 1 December 29, 2001 19:19
Stream Function physical significance? ram Main CFD Forum 0 February 21, 2001 08:45
Significance of damkohler number Pargaonkar Vijay Main CFD Forum 2 May 4, 1999 13:41
