May 14, 2021, 06:59 |
warning while defining wall motion
Usama
Rep Power: 6 |
Valve boundaries (1) min lift (0.000000) specified in motion file (pistondef1305.in) is inconsistent with expected geometry setup min lift (-1.000000). Please double-check.
am getting this error when I am defining user-defined BC of the piston motion I have no valves in my geometry...am simply defining a user-defined piston BC motion instead of converge to use it wrt piston motion...the file am using is attached below. Any suggestion apprecaited. |
May 14, 2021, 18:42 |
Praveen Srikanth
Rep Power: 5 |
Hi Usama,
The text file looks fine to me. Could you try importing the profile again to see if that works. It could be possible that it is reading in an old file which hasn't been overwritten. Praveen |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
