Home > Forums > Software User Forums > CONVERGE
species are missing within thermo.dat
Old   June 28, 2021, 02:46
Default species are missing within thermo.dat
ltl
Lynn
ltl is on a distinguished road
Hello everyone:
I want to change the reaction mechanism with GRI3.0, the "mech.dat" and "ther.dat" were replaced, but the "therm.dat" could not be read, the list of therm.dat species was blank, and the "mech.dat" appeared the message as “The following species are missing within Thermo data(therm.dat)”.
The content of "mech.dat" and "ther.dat" file derived from GRI-Mech 3.0,which is an optimized mechanism designed to model natural gas combustion, including NO formation and reburn chemistry.
Can you give be some advice? Thank you!
ltl is offline   Reply With Quote
Old   June 29, 2021, 09:51
awaikar's Avatar
Ameya Waikar
awaikar is on a distinguished road
Originally Posted by ltl View Post
Hello everyone:
Hey, can you please elaborate more on this.
Thank you
Ameya Waikar
Support Engineer II
New Applications
https://convergecfd.com/
awaikar is offline   Reply With Quote
Old   June 30, 2021, 09:14
ltl
Lynn
Thank you
Hello, awaikar:
Thanks for your reply.
To put it simply, the component cannot be recognized when importing the thermo.dat file, but the file content format is correct.
And I have solved this problem. When providing the thermo.dat file, a new .txt file should be built, then change it to a .dat file, and copy and paste the thermo data corresponding to the mechanism. My previous approach was to directly copy the new thermo data to the original thermo.dat file and overwrite the original data, which would cause an error.
Old   August 16, 2023, 13:30
Ali Tauseef
Totoralio is on a distinguished road
Hello, awaikar:
You my friend are a genius. I have been stuck on this exact problem for the last 3 hours, tried your method, and it worked. Many thanks.
Ali
Totoralio is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
