Home > Forums > Software User Forums > CONVERGE
Different Core number produce different calculation results
Old   December 6, 2022, 01:06
Post Different Core number produce different calculation results
shanghua chen
s.chen8 is on a distinguished road
I have met some situations recently. I set up an identical case and run in two different computers (one is 16 cores with 32 logic cores, the other one is 27 cores with 54 logic cores). The simulation showed an identical pressure trace before combustion and then a totall different combustion process afterwards. The one with less core predicted a faster combustion apparently. The combustion model is SAGE with RANS turbulence model, and following Converge recommd settings from example case.
My question is: does the core number affect calculation results? Is there any guidelines about setting up converge core number?
Thank you!
s.chen8 is offline   Reply With Quote
Old   December 8, 2022, 10:28
Chengqi Wang
Chengqi_Wang is on a distinguished road
Hi Shanghua.
Yes, the core number can affect the simulation results due to numerical perturbation, especially when the combustion system is unstable. For example, a computational diesel engine will not exhibit these oscillations whereas the GDI type simulation will show cycle-to-cycle oscillations. You can also see this cycle-to-cycle oscillation in experimental engine data. More detailed information can be found in this paper:
https://asmedigitalcollection.asme.o...T06A010/245357
As for your second question, there is no guideline about setting up core number.
Best,
Chengqi
Chengqi_Wang is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
Boundary condition problem (Freestream) KAYANO OpenFOAM Running, Solving & CFD 5 June 1, 2021 05:57
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
