Home > Forums > Mesh Generation & Pre-Processing Software > enGrid
meshing of free water surface for multiphase cfd
Old   August 11, 2017, 04:29
Default meshing of free water surface for multiphase cfd
bizzy is on a distinguished road
I would like to use enGrid for meshing of a towing tank for marine applications in OpenFOAM. enGrid creates tetrahedral meshes for the internal field and prismatic layers for the boundaries. In blockmesh+snapyhexmesh one can use multiple blocks to built up the mesh so that the two phases are seperated clearly and can be selected via setFields correctly. With enGrid is it possible to define a region where the faces of the tetrahedrons build up a planar surface within the internal field, so one can select the cells via setFields?
bizzy is offline   Reply With Quote
[Gmsh] 3D Free surface flow past circular cylinder meshing using GMSH arieljeds OpenFOAM Meshing & Mesh Conversion 7 January 14, 2017 12:57
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Free water jet impinging hot solid surface, including boiling hamdy Fluent UDF and Scheme Programming 5 August 19, 2012 19:52
Modeling of free surface water waves John N. CFX 3 January 21, 2009 00:07
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 11:57
