October 23, 2014, 04:29 |
Dynamic 2d chart
Rick
Rep Power: 26 |
Hi!
I saw an animation of a naca 0012 airfoil, which is located here: ftp://ftp.demec.ufpr.br/CFD/bibliogr...0.5-melhor.avi The interesting part is the dynamic 2d chart: it seems to monitor one point on the airfoil and insert the value vs rotation angle on the 2d chart dynamically. Is it possibile to do it in Ensight? More into details, I'm looking for a solution to dynamically plot in a 2d chart the absorbed power of a rotor machine (simulated with dynamic mesh): something like at time 0s there are no points on the chart, at first time step, let's say 0,01 s the first point is shown and so on till the end of the simulation time. Thanks! Last edited by ghost82; October 23, 2014 at 08:45. |
October 24, 2014, 17:06 |
Kevin Colburn
Daniele,
The short answer is no, not without some work. The long answer is that EnSight can plot two constants against each other (like alpha vs. Cl) as a scatter plot, but at each timestep, EnSight flushes the values from the previous timestep, so the graph does not "build upon itself". So, it does not build up the plot with values in that manner. Regards, Kevin Colburn
Kevin Colburn Computational Engineering International, Inc. www.ceisoftware.com kevin@ensight.com |
October 24, 2014, 17:07 |
Rick
Rep Power: 26 |
Thank you Kevin for your reply.
Google is your friend and the same for the search button! |
Dynamic SGS model procedure in Large eddy simulation | mrf6166 | Main CFD Forum | 39 | November 25, 2016 14:13 |
Regarding Negative volume detected in Dynamic mesh | Vinay Morabad | FLUENT | 10 | December 16, 2015 00:31 |
dynamic mesh or dynamic grid adaptation?? | IndrajitW | FLUENT | 3 | May 23, 2013 03:38 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 23, 2010 23:53 |
Chart empty | anna_67 | CFX | 2 | July 27, 2009 07:52 |
