Home > Forums > Software User Forums > Fidelity CFD
MUT/MU CLIPPED-FineTurbo
Old   June 3, 2012, 08:04
Question MUT/MU CLIPPED-FineTurbo
vavster is on a distinguished road
I am performing a turbomachinery steady simulation for transonic compressor stage using FineTurbo. The inputs are
Inlet : Total pressure extrpolated(The profile values have been defined except for constant turbulent viscosity 0.0001 m2/s)
Outet : Static pressure extrpolated
Numerical Model : CFL -3
Midway during the simulation I recieve a message "MUT/MU CLIPPED FOR X CELLS" and the the convergence curve goes wild.
I increased the MUCLIP value as suggested in the manual. But it shows the same message and behaviour as mentioned.
My concern is that the the constant turbulent viscosity may be the reason for this behaviour. I am not aware of a method to
calculate the turbulent viscosity. Any suggestions on the possible causes for this error message/ methods to calculate
turbulent viscosity are welcome. Thanks
vavster is offline   Reply With Quote
Old   June 7, 2012, 10:54
Alberto
Super_boccia is on a distinguished road
granted that I use NUMECA just from a couple of months, and I've found the same problem in some simulations, but the residul didn't have a wild behaviour.
Personally I think that the reason is due to the profiles that you use as boundary conditions; they could be too "hard" for your machine. In particular if you have a transonic field, it doesn't help the convergence.
Let me know.
Super_boccia is offline   Reply With Quote
Old   June 10, 2012, 01:49
CJ
oldshoes81 is on a distinguished road
Send a message via MSN to oldshoes81 Send a message via Skype™ to oldshoes81
Please do check your mesh quality and make sure the qualities are following the criteria.
Good luck.
Regards
CJ
NUMIT Enterprise, Malaysia
+6 017 656 3436
http://maccom-numit.blogspot.com
http://www.numit.com.my
Email : seiko.q@numit.com.my
oldshoes81 is offline   Reply With Quote
Old   June 17, 2012, 06:01
@ Alberto
The stage is transonic field. I tried using constant profile conditions but the result is the same.
@ Old shoes
My mesh conforms to the numeca recommended values wrt aspect ratio, orthogonality etc. The current mesh size is about 700000 for the stage. i will refine the mesh and try checking the results.
Thanks
Vikram
Old   July 30, 2012, 10:32
CJ
Is there any improve computed results after your refinement? What is the Reynolds Number of your case?
Regards
CJ
+6 017 656 3436
Old   July 31, 2012, 14:08
Default Help need to simulate flow around Contra rotating Fan
venkatesh
venkat_aero2007 is on a distinguished road
I am trying to simulate flow around Contra rotating Fan using Full Non Matching
Mixing Plane. I meshed my geometry in Autogrid5 and I am trying to simulate in FineTurbo. The flow is steady and incompressible with a blade speed of 1029 rpm. I use Spalart–Allmaras turbulence model with velocity inlet (68 m/s), pressure outlet (Radial equilibrium) as the boundary condition and I imposed Farfield velocity as 68 m/s. The Periodic angle for the front rotor is 32.7272 degree and 40 degree. There are nearly 6.5 million cells.
In the initialization of simulation, I gave 98500 pascal as inlet pressure and 90000 pascal as pressure in mixing plane. I ran simulation, after two iteration it say solution blow out, Process killed, Crashed. I tried with different boundary condition but nothing helped me. I am not able to figure out the problem.
Please Can anyone give me some suggestions to run my simulation.
venkat_aero2007 is offline   Reply With Quote
Old   August 1, 2012, 07:39
Mark
daxterss is on a distinguished road
I think it is a problem with your boundary conditions. Which value of CFL are you using? try to reduce it
Sorry but i am not an expert in that problems...
daxterss is offline   Reply With Quote
Old   August 1, 2012, 07:53
venkatesh
Hi daxterss,
Thanks for your reply. The value of CFL that I use is 3. I tried to reduce it to 1 but again the calculation blows up after two iteration. Currently I am using velocity inlet and pressure outlet. Could you please tell me what mistake am I doing in boundary condition.
Old   August 1, 2012, 07:58
Mark
Sorry but I am not an expert in this topic.
Are you running your simulation in the finest grid? or a coarse level? Try to get run in the coarsest level. And when you get the convergence, move to the next level using as inital solution, the solution you got before.
Old   August 1, 2012, 08:07
venkatesh
Again thanks for your quick reply. I have started my calculation at coarsest grid level. I did as you said but still I have the blow up problem. I don't know what to do.
Old   August 1, 2012, 08:11
Mark
Ok, if you try to converge in the coarsest grid and you can't (the coarsest is the grid, the easiest is to converge) I am pretty sure that the problem is with your b.c, but I can't help with this... Sorry
Hope you can solve your problem
Old   August 1, 2012, 08:15
venkatesh
Thanks for your suggestion. one quick question. can i try with pressure inlet instead of velocity inlet. The problem is I don't know to set up pressure inlet. At inlet it show me only parameters associated to velocity.
Old   August 1, 2012, 08:20
Mark
Sorry but I don't know which b.c are the best for your problem
Old   August 1, 2012, 08:21
venkatesh
Old   August 1, 2012, 08:22
venkatesh
ok I will work on it and post my issues with my simulation.
Old   August 1, 2012, 09:54
CJ
What is the number of mesh you have within your fine grid and what is the number of mesh you have within your coarse grid?
Regards
CJ
+6 017 656 3436
Old   August 1, 2012, 16:23
venkatesh
I dont know how to check number of mesh in fine grid and coarse grid. My Mesh has around 5.8 million points. The Number of grid level in quality report shows that 4 3 2. I stated the calculation with coars grid initialization with a CFL number 3. I dont know much about preconditioning parmater so I kept the default value. I will post some images so that you can check my boundary conditions and figure out my mistake. The flow is incompressible and Steady.
Old   August 1, 2012, 16:27
venkatesh
In Preconditoning parameter I also tried Merkel method but it does not work,solution blow up after two iteration.
Old   August 1, 2012, 17:44
venkatesh
My Calculation is running now. I reduced the CFL number to 0.0000001. In the user manual it was suggested to have a minimum CFL number between 0.5 to 1.
Problem is that MAX_RES (Maximum residual) increases with iteration. MIN_RES (Minimum Residual) decreases with iteration which is a normal thing. There is almost no variation in the Force quantities with increase in iteration.
Dont know whether the calculation is running in right path. How can we check whether the calculation is running in right path.
Old   August 1, 2012, 21:51
venkatesh
I ran the calculation with CFL number = 0.000001. I started the calculation in coarse grid for 200 iteration. the residuals were decreasing slowly. After 200 iteration, I started to run in fine grid but the solution blew up after 213 iteration.
Can you tell me the reason why the solution blew up in finest grid. thanks in advance for suggestions
Error importing mesh from Hexpress to Fineturbo cheche Fidelity CFD 4 January 27, 2011 03:35
Running FineTurbo on a Linux Cluster Philipp Höfliger Fidelity CFD 3 May 6, 2004 08:47
