Home > Forums > Software User Forums > Fidelity CFD
Hubless Propeller in AutoGrid
Old   November 1, 2016, 17:32
Question Hubless Propeller in AutoGrid
Syamsi Firdaus
syamsiprop is on a distinguished road
I wanna ask something,
as i know, AutoGrid need 3 important definition : Shroud, Hub and Blade
i've project to analyze hubless propeller. its possible to analyzing in Fine Turbo with meshing in AutoGrid?
When i try to link Geometry, I cant link blade surface to blade. Hope all of you can help me
Thank you
Attached file : Capture imported Geometry in Import CAD Window
syamsi11@mhs.ne.its.ac.id
syamsiprop is offline   Reply With Quote
Old   November 7, 2016, 02:30
Colinda
colinda1 is on a distinguished road
The blade is physically connected to the shroud then? Sure it is possible to analyze in AutoGrid. You just need to define a virtual hub and add a block for the center part e.g. in a 3D effect.
colinda1 is offline   Reply With Quote
Old   November 18, 2016, 08:27
Smile
Syamsi Firdaus
Hi collinda
Thanks for your response.
i still confuse about that virtual hub and block for the center. may you explain more specific to me?
Old   November 21, 2016, 10:07
Colinda
In your CAD or in the CAD import window of AutoGrid5 you may define a virtual hub. What I mean by virtual that you will mesh it as if it is a wall but then you can add a 3D effect in your AutoGrid5 project that inserts a (butterfly)block in the part from 0 radius up to the hub and that is connected with a full non-matching connection for example.
So the virtual hub is not a real wall but a connection to the inner fluid region.
Alternative to a 3D effect in AutoGrid5, the block can be added in IGG.
autogrid5, numeca
Propeller calculation toil CFX 15 May 22, 2017 04:06
motion constraints for a boat moved by propeller simon-2 OpenFOAM Running, Solving & CFD 0 September 14, 2015 16:28
Propeller mesh problem for Autogrid 5 Johnson Shi Fidelity CFD 2 August 9, 2014 03:56
(AutoGRID 5) Problem in Geometry definition of propeller venkat_aero2007 Fidelity CFD 14 July 31, 2012 14:05
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 17:22
