Home > Forums > Software User Forums > Fidelity CFD
Import CAD model
Old   February 19, 2012, 12:20
Default Import CAD model
sajad
sajad is on a distinguished road
I have a 3D cad model of an existing runner in CATIA (.igs extension) ,l want to do an optimization process on it with Numeca/Design 3D so i have to convert it to .geomturbo format , what's the easiest way to do it?
I tried to do it using "import IGES" & "import & link CAD" options in Autogrid , but it doesn't work, could you tell me what is the problem? and is there any other way to do it?
thanks
sajad is offline   Reply With Quote
Old   February 25, 2012, 23:26
Hamid Zoka
Hamidzoka is on a distinguished road
"Geomturbo" format generates the blades through the points that define suction and pressure sides and also hub and shroud. So IGES or other formats based on lines and surfaces cannot be directly used to define geomturbo. Therefore you need some handy work in your 3D modeling software to exploit those points to generate your geomturbo file.
Regards
Hamidzoka is offline   Reply With Quote
Old   February 26, 2012, 04:18
sajad
thanks for your reply hamid
I think it's easier to "import and link" my cad geometry in autogrid and then export it to .geomturbo format, i have done it for simple geometries (for example 2D geometries of hub & shroud) . but now my problem is to import the 3D geometry of whole runner in autogrid . when I import it in autogrid it doesn't do anything, maybe there is some problem about my geometry?
Regards
Old   March 2, 2012, 13:50
Hamid Zoka
Maybe there is a problem with your geometry.
normally autogrid accepts simple and basic shapes of blades. in case your model is sophisticated perhaps you need to simplify it.
regards
Old   March 4, 2012, 05:08
sajad
Originally Posted by Hamidzoka View Post
regards
Hi
I imported my geometry in autogrid finally. but now i have a lot of errors : "discontinuity" in hub & shroud or leading & trailing edge , leading edg or trailing edge "doesn't intersect" hub or shroud , "overlapping" ,etc! i am really confused!
it seems that you are well familiar with this software , could i have your contact information for more help?
(I am master student in elm o sanat university and i couldnt find anyone around that could help me on this software)
Regards
Old   March 5, 2012, 23:07
Hamid Zoka
this is my email address: hamid.zoka@gmail.com
regards
Old   May 2, 2012, 04:15
Ion
JohnnyB is on a distinguished road
hello...
watch this: http://www.youtube.com/watch?v=al6VvL6OLTM
JohnnyB is offline   Reply With Quote
Old   August 2, 2013, 11:57
Question
Chaithu
Irondome is on a distinguished road
Hi friends..
I have a similar problem but, I have .geomTurbo files and have to convert it to igs to generate the blade ?
I am new to catia and donno how to go about it. Can someone please help me.
Thanks a lot
Irondome is offline   Reply With Quote
cad model, geomturbo, import, numeca
Can Fluent Import New Turbulence Model By UDF? Andy Cong FLUENT 4 March 25, 2016 13:14
Centrifugal Pump CAD Model Required for validation bhatiadinesh CFX 1 June 25, 2013 04:16
How to import 2D wireframe model to GAMBIT vrd FLUENT 0 June 12, 2011 12:47
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
I-DEAS CAD data import with boundary conditions Yunus Siemens 1 June 1, 2001 10:04
