Home > Forums > Software User Forums > Fidelity CFD
Import .igs in Autogrid5
Old   November 6, 2013, 06:00
Default Import .igs in Autogrid5
Deneriaz Alphonse
alederiaz is on a distinguished road
Dears,
I am a beginner of Autogrid and I tried to import my geometry but, obviously, I found some difficulties.
I understand that intersections between hub/blade/shroud are necessary but I am not able to select the right surfaces to define my blade. I mean, I discovered that if I use some tools to create surfaces ( like revolve, fill) in CAD, these surfaces will not recognized. is it weird?
which characteristics are necessary to recognize a blade correctly?
Please, comment. everything should be useful for a beginner like me.
Thanks
alederiaz is offline   Reply With Quote
Old   December 6, 2013, 03:34
CJ
oldshoes81 is on a distinguished road
Send a message via MSN to oldshoes81 Send a message via Skype™ to oldshoes81
I could not understand your question. Usually any CAD should do the job for you.
Regards
CJ
NUMIT Enterprise, Malaysia
+6 017 656 3436
http://maccom-numit.blogspot.com
http://www.numit.com.my
Email : seiko.q@numit.com.my
oldshoes81 is offline   Reply With Quote
Old   December 9, 2013, 09:30
Deneriaz Alphonse
I had troubles importing geometry from .igs .
Are there constraints for the import file in autogrid5?
what exactly does ''bad streamwise orientation'' error mean when i am setting leading and trailing edge?
how can I solve discontinuity issues in the channel without change the geometry?
I would like to keep the nose of the runner but i do not know how to describe the hub-line. probably this old pic can help to understand what I am saying
http://tinypic.com/r/2nt8rpv/5
Thanks
Old   December 10, 2013, 08:25
Hamid Zoka
Hamidzoka is on a distinguished road
importing .igs file to autogrid is not always successful.
regarding the .igs model following tips come to my mind:
- separate suction and pressure sides so that LE and TE lines can be distinguished.
- no manufacturing details such as fillets, roots, tip cavities, cooling passages and cooling holes should exist in your model.
- surfaces of suction side and pressure side should be smooth enough
- endwalls can be separately defined through hub and shroud curves and should not be neccessarily included in .igs model.
Hamidzoka is offline   Reply With Quote
Old   February 24, 2014, 04:07
Colinda
colinda1 is on a distinguished road
Originally Posted by alederiaz View Post
Dears,
Please note the list of supported geometry entities in the AutoGrid5 manual. For example trimmed parametric surfaces (type 144) and offset surfaces (type 140) are supported for IGES import but some other types exist in IGES format that can not be imported in AutoGrid5.
colinda1 is offline   Reply With Quote
[PyFoam] First discussion thread about PyFoam braennstroem OpenFOAM Community Contributions 338 March 17, 2022 14:05
I developed an FEM toolkit in Java: FuturEye nkliuyueming Main CFD Forum 7 January 29, 2016 13:28
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Import transient cfx-results for static structural analysis in Ansys WB 13 Colt Seavers ANSYS 1 August 11, 2011 06:01
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
