Home > Forums > Software User Forums > Fidelity CFD
How to compute viscous forces in OpenLabs script
Old   August 2, 2017, 10:47
Default How to compute viscous forces in OpenLabs script
FineOpen User
FineUser is on a distinguished road
Dear all,
In order to compare different airfoils at the same lift coefficient, I wrote an OpenLabs script* for driving the AoA into a value corresponding to the target CL (e.g. 0.5).
Since OpenLabs do not give access to flow forces or residuals*, I had to compute them in the openLabs script by integrating the pressure on solid walls for the inviscid force and the viscous stresses for the viscous force.
However, when comparing the openLabs results with the forces computed by the solver (in the .wall file) I found the following:
-> The inviscid (pressure) force is exactly the same as in the .wall file.
-> The viscous force is different.
Using SA turbulence model, the error is relatively small but it reaches 30% with Laminar NS computations.
No improvement is obtained by using the "Extrapolate" keyword for the gradient computation at solid boundaries (in this case even the inviscid force value becomes wrong).
Hence my question: How the viscous stress tensor is computed in FineOpen ??
I used the following equation (in index notations):
Tauij = (µ + µt) (dui/dxj +duj/dxi - (2/3) δij duk/dxk)
Below are the Open Labs commands used for the computation of the flow forces:
=>AUXTERMS
# components of the flow forces.
@AUXTERM:PressForceX
->EXPRESSION:INTEG2D(StaticPressure*NormalX,ALLSOLI DS)
@AUXTERM:PressForceY
->EXPRESSION:INTEG2D(StaticPressure*NormalY,ALLSOLI DS)
@AUXTERM:PressForceZ
->EXPRESSION:INTEG2D(StaticPressure*NormalZ,ALLSOLI DS)
@AUXTERM:ViscForceX
->EXPRESSION:INTEG2D(ViscStressX,ALLSOLIDS)
@AUXTERM:ViscForceY
->EXPRESSION:INTEG2D(ViscStressY,ALLSOLIDS)
@AUXTERM:ViscForceZ
->EXPRESSION:INTEG2D(ViscStressZ,ALLSOLIDS)
# components of the viscous force
@AUXTERM:ViscStressX
->EXPRESSION:-Viscosity*(Tauxx*NormalX+Tauxy*NormalY\
+Tauxz*NormalZ)# - sign because the force is applied from fluid to solid
@AUXTERM:ViscStressY
->EXPRESSION:-Viscosity*(Tauxy*NormalX+Tauyy*NormalY\
+Tauyz*NormalZ)
@AUXTERM:ViscStressZ
->EXPRESSION:-Viscosity*(Tauxz*NormalX+Tauyz*NormalY\
+Tauzz*NormalZ)
# components of the viscous stress tensor
@AUXTERM:Tauxx
->EXPRESSION:2*(GRAD(Vx,x)-(GRAD(Vx,x)+GRAD(Vy,y)+GRAD(Vz,z))/3)
@AUXTERM:Tauyy
->EXPRESSION:2*(GRAD(Vy,y)-(GRAD(Vx,x)+GRAD(Vy,y)+GRAD(Vz,z))/3)
@AUXTERM:Tauzz
->EXPRESSION:2*(GRAD(Vz,z)-(GRAD(Vx,x)+GRAD(Vy,y)+GRAD(Vz,z))/3)
@AUXTERM:Tauxy
->EXPRESSION:GRAD(Vx,y)+GRAD(Vy,x)
@AUXTERM:Tauxz
->EXPRESSION:GRAD(Vx,z)+GRAD(Vz,x)
@AUXTERM:Tauyz
->EXPRESSION:GRAD(Vy,z)+GRAD(Vz,y)
* It will be great if Numeca includes this possibility in a future release.
FineUser is offline   Reply With Quote
Old   August 3, 2017, 07:15
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Dear FineUser,
this is some interesting but really advanced request. I would ask you to state your problem in the official NUMECA forum, which is accessable through the customer portal (portal.numeca.be). There is a special forum for OpenLabs questions (http://portal.numeca.be/forum/viewforum.php?f=23).
The person who is responsible for licensing of our software in your company/institute is called the "Master User". He can create an account for you if you don't have one, in order to have access to the customer area.
Kind regards,
Holger
DarylMusashi is offline   Reply With Quote
Old   August 3, 2017, 09:30
FineOpen User
Dear Holger,
Thank you for the advise, I will try to ask the question there.
Actually, my AoA controller works fine and converges to the target Cl that I specify. However, as the viscous force is not correctly estimated, the Cl coefficient computed in my OpenLabs script is different from the one computed through FineOpen results.
I will not tell you how many combinations of the gradients * viscosity terms for the stress tensor I tried in order to arrive at a similar viscous force but without success. I have even tested with some simple cases (flat plate, backward facing step ...).
Kind regards,
Old   August 3, 2017, 10:15
Holger Dietrich
(Automatically) modifying the AoA in order to achieve a lift coefficient = 0.5 is exactly the same procedure as in the drag prediction workshops (DPW), in a few of them NUMECA participated, too. You have good chances that someone in our official forum can help you out.
Old   August 3, 2017, 11:00
FineOpen User
Actually, I think they participated only in the DPW4, strangely the presentation of Numeca is the only one missing in their website https://aiaa-dpw.larc.nasa.gov/Works...sentations.htm.
Thank you anyway,
Wrong forces coming from forces function object in controlDict Jason_Duguay OpenFOAM Post-Processing 0 April 13, 2016 09:07
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat CFD XUE FLUENT 3 March 18, 2015 03:28
forces in interFoam Svensson OpenFOAM Post-Processing 2 May 9, 2012 13:31
Calculate forces without hydrostatic pressure geir_oye FLUENT 4 November 12, 2009 09:12
Forces viscous calculation in VWT with OpenFOAM 15x terrybarnaby OpenFOAM Running, Solving & CFD 0 November 28, 2008 08:39
