June 2, 2018, 09:57 |
Mesh Merge Information
Peter Silie
Rep Power: 8 |
I tried to link a new mesh to an existing project. Afterwards I got the following Message: The mesh file (meshname) and the project (projectname) do not have the same topology. What does it mean? I click Merge Mesh definition (see attached) and the message disappears. Greetings |
June 3, 2018, 07:00 |
Holger Dietrich
In FINE/Turbo you can use an already set up project and link a new mesh. This makes sense if the topology of both meshes is similar but only the number of grid points differ (for example in case of a mesh refinement study).
After you merged the old project with the new mesh you should definitely check all settings, especially the boundary conditions tabs if all patches (inlet/outlet/solid) are defined correctly. |
June 3, 2018, 11:04 |
Peter Silie
Rep Power: 8 |
Thanks for your answer.
But because of this message, my script stops working. Is there a script command, to say Fine/Turbo that I want to click "Merge Mesh"? Greetings |
June 3, 2018, 11:13 |
Holger Dietrich
As far as I know there is no such script command to automatically merge the mesh. But you could (once again) set up your project from scratch, save the script file (File -> Script -> Save all) and execute this script. In this script you can then set the path of the linking mesh.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
How to use mesh information in other source file | TurbJet | OpenFOAM | 11 | February 9, 2022 07:27 |
[ANSYS Meshing] Output Ansys WorkBench mesh information | KiiiKi | ANSYS Meshing & Geometry | 0 | September 17, 2014 10:42 |
[ICEM] Merge created block resulting in not connected mesh | imamwfgf | ANSYS Meshing & Geometry | 2 | October 20, 2013 06:22 |
about merge mesh | lian | Main CFD Forum | 3 | February 29, 2008 10:47 |
