How to use mesh information in other source file
Like Tree3Likes
  • 1 Post By Taataa
  • 2 Post By TurbJet
Old   January 23, 2018, 13:28
Unhappy How to access mesh and user-defined fields in other source file
TurbJet is on a distinguished road
Hello to everyone,
Currently I am using MPPICFoam to track particles. Now I have to modify one of its source files, which needs to access the information like mesh and other user-created fields. So how am I gonna do that? How am I gonna access other information outside the source file, in this case mesh, user-created fields? Should I include some headers for the mesh or something else? I tried to include headers like "polyMesh.H" "fvCFD.H", but it did not work out.
I am kind of desperate now. Hope there is someone could help me out here.
Thanks a lot.
PS:
to be more specific. I am doing Lagrangian Particle tracking and using MPPICFoam. Currently I am trying to make some modification to the file Cloud.C. What I am trying to do is to loop over all the mesh and particles, and then check the mesh where the particle is at, see how is the porosity of this mesh; if the porosity of this mesh is 0, delete the particle, otherwise, do nothing.
the codes I add:
forAll(mesh.C(), celli)
if (( abs(mesh().C()[celli].x() - p.position().x()) < posdiff )
&&( abs(mesh().C()[celli].y() - p.position().y()) < posdiff ))
if (abs(porosity[celli]) <= threshold)
deleteParticle(p);
where posdiff and threshold are just constants I defined, and porosity is a new field I create; deleteParticle is a member function of Cloud.C; p.position() is to access the coordinates of the particles.
when I compile the codes, the compiler gives:
/opt/openfoam4/src/lagrangian/basic/lnInclude/Cloud.C: In member function ‘void Foam::Cloud<ParticleType>::move(TrackData&, Foam::scalar)’:
/opt/openfoam4/src/lagrangian/basic/lnInclude/Cloud.C:309:13: error: ‘mesh’ was not declared in this scope
/opt/openfoam4/src/OpenFOAM/lnInclude/UList.H:430:30: note: in definition of macro ‘forAll’
for (Foam::label i=0; i<(list).size(); i++)
UPDATE:
I figured out the mesh problem (for those who might be interested, see my reply below at #6). And I was inspired by this thread:
const volVectorField& U = db().lookupObject<volVectorField>("U") gives runtime error
But I am still not able to access my self-created field "porosity" within this scope, i.e., within this Cloud.C file.
I create the porosity field by add codes in createFields.H, and write another header file to compute the field. Then I include this header file at the beginning of the solver MPPICFoam.
The compiler says the same thing:
error: ‘porosity’ was not declared in this scope
Anyway, to narrow this down: how am I gonna retrieve self-created field within other source file?
Any thoughts, guys?
TurbJet is offline   Reply With Quote
Old   January 23, 2018, 19:41
could someone please answer my question? I am desperate
Old   January 24, 2018, 14:19
anyone can help me out?
Old   January 25, 2018, 23:43
Taher Chegini
Taataa is on a distinguished road
You need to be more specific about your problem if you want help.
Regarding the mesh not declared error you need use it like this:
mesh().C()
in the newer versions of OF.
Tobi likes this.
Taataa is offline   Reply With Quote
Old   January 30, 2018, 12:40
mesh().C()
the compiler gives
I am doing Lagrangian Particle tracking and using MPPICFoam. Currently I am trying to make some modification to the file Cloud.C; the goal I want to achieve is that I want to access the mesh center coordinates to compare with the coordinates of particles.
the codes I add:
deleteParticle(p);
I am not sure, but I think the fvMesh info is just not available within this scope, even if I include the header file "fvMesh.H" into this .C file. And I tried to add the brackets after "mesh" as you suggested, but it still not work.
Now I am thinking about passing mesh as an argument into the member function of Cloud.C, but that needs to modify a chunk of other functions.
So I am running out of thoughts.
Old   January 30, 2018, 18:02
I kind of figured out this mesh problem.
I added few sentences in the code:
const objectRegistry& db();
const volVectorField& U = db().lookupObject<volVectorField>("U");
const fvMesh & mesh = U.mesh();
and the compiling worked out without further warning, even though I am not sure if the codes as a whole would work.
But the remaining question is: how am I gonna make the self-created field "porosity" to be accessible within this context? The compiler says the same thing:
tooran and charryzzz like this.
Old   January 30, 2018, 19:54
following the previous procedure, I tried the following:
const volScalarField& porosity = db().lookupObject<volScalarField>("porosity");
to include my self-created scalar field "porosity". However, the compiler said:
Make/linux64GccDPInt32Opt/modDPMFoam.o: In function `_GLOBAL__sub_I_modDPMFoam.C':
modDPMFoam.C: (.text.startup+0x73) : undefined reference to `db()'
modDPMFoam.C: (.text.startup+0xc5) : undefined reference to `db()'
collect2: error: ld returned 1 exit status
make: *** [/home/ipalab/OpenFOAM/ipalab-4.1/platforms/linux64GccDPInt32Opt/bin/modDPMFoam] Error 1
Seems it has some linking issue. Does anyone know what's wrong with it? Any thoughts?
Old   February 1, 2018, 17:42
Taher Chegini
This is the way that I would declare velocity and cell centers:
const volVectorField& U =  mesh().lookupObject<volVectorField>("U");
const volVectorField& centers = mesh().C();
Regarding the dictionary, here is an example for finding air density in transportProperties:
const objectRegistry& db = mesh().thisDb();
const dictionary& transportProperties =
    db.lookupObject<IOdictionary>
        "transportProperties"
dictionary alpha2
        transportProperties.subDict("air")
dimensionedScalar rhoAir
        "rhoAir",
        dimDensity,
        alpha2.lookup("rho")
You can adjust it based on the dictionary and sub-dictionaries.
Old   February 2, 2018, 12:29
dictionary alpha2
        "rhoAir",
        dimDensity,
actually, I was trying to declare mesh, not velocity.
Old   February 2, 2018, 12:47
dictionary alpha2
        "rhoAir",
        dimDensity,
Basically, I did this:
IOdictionary porosity
IOobject
"porosity",
this->db().time().constant(),
this->db(),
IOobject::READ_IF_PRESENT,
IOobject::NO_WRITE
The declaration of U and mesh were a success, but the declare of the self-created field "porosity" was not.
Old   March 5, 2020, 18:56
tooran
tooran is on a distinguished road
I created a new viscosity model base on HerschelBulkley model . I want to model the following structure:
If y< 0.048
Then return...
Else return....
I am trying to access the points in the mesh inside the the HerschelBulkley class.So I added the following loop on the calcNu() function in HerschelBulkley :
forAll (etat, cellI)
etat[cellI]=mrsh.c()[cellI].y();
If (etat[cellI]<0.048)
But When I compiled the error appeared :
"mesh is not declare in this scope"
I solved this error by adding the following lines:
Now the libary compiles with out errors,but when I want to run the case with the solver simple foam , the following error appears:
Undefined symbol: _ZN4Foam15viscosityModels2dev
Could anyone help me?
Thanks
tooran is offline   Reply With Quote
Old   February 9, 2022, 07:27
hari charan
saicharan662000@gmail.com is on a distinguished road
Hello TurbJet,
I had the same problem can you go through my post . I am sharing the link below.
request for a field in object registry failed
Thanks in advance.
saicharan662000@gmail.com is offline   Reply With Quote
mesh;
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
