Home > Forums > Software User Forums > Fidelity CFD
FSI simulation of wind turbine blade using NLH method
Like Tree1Likes
  • 1 Post By Ko_Shine
Old   August 31, 2018, 07:12
Default FSI simulation of wind turbine blade using NLH method
Ko Shine
Ko_Shine is on a distinguished road
I’m trying to run FSI simulation of wind turbine blade using NLH method and modal coupling approach. For the first step, I tried to extend the steady simulation of the wind turbine blade provided in the NUMECA Fine/Turbo’s tutorial to NLH computation. I followed the steps from another tutorial case, Flutter Analysis of Axial Compressor, to implement NLH method. To be more specific, the number of frequencies per perturbation is 1 and the max number of perturbations of per blade row is 1. For the mode shapes of the blade, I calculated and exported in ANSYS. The type of mesh deformation is Radial Basis Functions --> Transfinite Interpolation. The steady solution is set as initial solution. However, the run is stuck at the stage of “Constructing matrix C with reduce patch” (please see attached image). I waited for more than an hour and it did not go any further. I’m wondering whether the steps would be different to implement NLH method for the wind turbine blade case. I’d also be grateful if someone could give me any suggestion or any advice to solve this problem.
Thank you very much in advance.
Ko_Shine is offline   Reply With Quote
Old   April 22, 2020, 03:31
agoverno
agoverno is on a distinguished road
Hello Ko_Shine,
did you manage to fix the problem? I have the exact same problem and I am still trying to fix it.
Best,
agoverno
agoverno is offline   Reply With Quote
Old   April 22, 2020, 06:27
Ko Shine
Yes, I solved the problem. It was due to the number of nodes involved in the mode shape. Keep the number of nodes lower than 10,000 or even much lower. Otherwise, it will take ages.
I hope it helps.
agoverno likes this.
Old   April 22, 2020, 07:08
agoverno
Alright, I had a feeling it was about that. Thank you so much I will try it.
wind turbine blade flow simulation rsskarthikeyan FLUENT 0 May 27, 2015 05:40
[ICEM] Hexa meshing of Wind Turbine blade. Help for Newbie please federvo.mala ANSYS Meshing & Geometry 4 June 8, 2013 03:19
advice on wind turbine simulation? level CFX 2 June 11, 2012 04:31
2D Simulation of Savonius Wind Turbine ravindersingh FLUENT 4 December 9, 2011 13:00
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
