Home > Forums > Software User Forums > Fidelity CFD
Accuracy of ANN
Old   April 28, 2020, 12:53
Default Accuracy of ANN
abdul
eng.abdul is on a distinguished road
What are the criteria for evaluating the accuracy of ANN using Design3D? I am not talking about the effects of number of initial training samples. Thanks
eng.abdul is offline   Reply With Quote
Old   May 3, 2020, 08:42
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
If we talk about the software itself accuracy of ANN like other iterative processes can be controlled either by max. iterations or the acceptable error within the iterations.
If the accuracy of the ANN to mimic the output targets (i.e. efficiency, power,etc.) is intended, no explicit instruction exists. you should always check its outputs with those of simulations and keep in mind that as the number of cases increases the accuracy of ANN may increase.
Fortunately it is possible to check the performance of ANN at each design iteration in Design3D. When number of iterations are sufficiently large you will see that ANN predictions and simulation results will come together.
Regards
Hamidzoka is offline   Reply With Quote
Artificial Intelligence in CFD Naresh yathuru Main CFD Forum 71 March 29, 2021 23:32
Time integration order of accuracy when solving acoustic wave equation using FEM lzhaok6 Main CFD Forum 20 May 3, 2017 11:22
upwind finite volume order of accuracy less than one ?? dgfem Main CFD Forum 7 June 1, 2015 04:02
Temporal accuracy ganesh Main CFD Forum 0 February 29, 2008 05:32
accuracy of Discontinuous Galerkin Qu Kun Main CFD Forum 0 September 6, 2004 09:19
