March 2, 2020, 15:47 |
Multigrid with FNMB connection
David Hunter
Hi everyone!
I'm meshing my geometry in IGG and I need to create a FNMB connection. The problem is that my grid level in the "i" direction is reduced to 1 when I define the connection. Is it possible to to create a mesh with several grid levels even if I have a FNMB connection? Thanks in advance. |
March 9, 2020, 04:54 |
Colinda
Rep Power: 13 |
It should be possible to keep the original grid count. Setting up a FNMB connection should not change the grid point distribution.
Hard to tell though what could be the cause of trouble in your case. Maybe if you describe your case in more detail with the steps you performed? Best regards, Colinda |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 10:45 |
multigrid | sureshkumar | Main CFD Forum | 0 | June 9, 2006 01:20 |
Multigrid applied to k-e models | Paulo Zandonade | Main CFD Forum | 9 | May 24, 1999 08:10 |
