Home > Forums > Software User Forums > Fidelity CFD
switching from Fine5.3 to Fine 6.1
Old   July 30, 2003, 07:44
Default switching from Fine5.3 to Fine 6.1
voyer arnaud
I had a project under Fine5.3 with a computation (let's say computation 1). I duplicated this project and started it under Fine6.1. Then I ran a new computation using "computation 1" as initial solution.
I made exactely the same thing under Fine5.3 and the convergence history is different. If using Fine5.3 there is a perfect continuity with "computation 1", there is no continuity under Fine6.1 and the amplitude of the oscillations I had increased!
I noticed some changes in the control_variables/expert_parameters. Some defaults values changed and there is new parameters like IRSMCH. These changes can be the cause of my troubles?
Thank U.
Switching on LES in 2D mode of fluent Josef Dubsky FLUENT 27 March 16, 2016 13:49
3D axis switching in a turbulent jet fluidsguy1001 FLUENT 0 November 6, 2007 17:18
switching "ON" viscosity Vishal Siemens 1 October 10, 2005 06:28
Switching from Fluent to CFX Terri Novotny CFX 1 December 7, 2004 21:59
switching from build 2 ICEM CFD 4.CFX bogesz CFX 4 February 27, 2004 01:31
