Home > Forums > Software User Forums > Fidelity CFD
negative efficiency!!
Old   November 24, 2003, 20:44
Default negative efficiency!!
firespring
When I simulate a turbine impellor's flow,the efficiency is negative,Why!
Old   November 25, 2003, 20:24
Default Re: negative efficiency!!
NUMECA-Beijing
Hello Zhang,
Solver blows up, incorrect BC or rotationary settings may lead to such problems.
However, we would like to invite you to send email to support@numeca-beijing.com , describing you case details, your settings, etc. We then can process this support request.
Regards
Support center of NUMECA-BEIJING
Old   September 26, 2004, 22:41
SAM
this may be due to defining rotatin axis
give value for rotaing axis as -1 instead of +1
Bye
Negative propulsive efficiency of a moving airfoil zonexo Main CFD Forum 4 March 7, 2007 00:16
about efficiency of compressor linyi Main CFD Forum 4 September 1, 2004 07:34
Combustion Efficiency Justin Rencher FLUENT 0 April 22, 2004 15:39
The cost of CFD efficiency Ben Metodiev Main CFD Forum 5 May 24, 2001 22:27
CPU efficiency over 100% !! X. Ye Main CFD Forum 6 September 7, 1999 10:07
