Home > Forums > Software User Forums > Fidelity CFD
Using the Fine/Design3D module
Old   June 7, 2005, 21:56
Default Using the Fine/Design3D module
yan
an diagonal water pump with 4 blades of blunt leading edge and trailing edge. while using the simple Bezire curve(GA,B1,B2) to construct the camber curve, I limit the thickness distribution to be constant parameters. the free parameters are the 3 angles of camber curve(GA,B1,B2); the two angels of Lean Law. however, i could not control the lenth of camber curve in every sections which will change with the angel GA. of course i could limit GA in every section as a constant value but it is not the case actully. i don't know whether i have post my problem clearly. the forum do not support picture uploads. if you want i can email my bad DATABASE SAMPLE to you who send me emails.
it's my first time to use the Fine/Design3D module.
Old   September 21, 2005, 18:53
Default Re: Using the Fine/Design3D module
don't they support this software?
Old   September 21, 2005, 22:02
yan
I'm afraid so
Old   September 6, 2006, 06:14
hong
chao
Help for Fine/Design3D stewart Fidelity CFD 1 September 6, 2006 06:14
the problem about design3D younger Fidelity CFD 1 March 21, 2006 10:44
a survey on design3d abscissa Fidelity CFD 0 December 1, 2004 02:41
MHD Module Benny FLUENT 0 March 16, 2004 05:04
Re:MHD Module Benny FLUENT 0 November 16, 2003 22:25
