Home > Forums > Software User Forums > Fidelity CFD
"spanwise line broken ?"
Old   June 26, 2009, 05:10
Default "spanwise line broken ?"
liangli
liang is on a distinguished road
Hi to all!
FINE shows me like that :
Non matching connection # 1 Fluid type # 1
Non matching connection # 1 - Grid level 1
! SPANWISE LINE BROKEN
what does it mean? Dose it mean there's something wrong with tht "Rotor/stator " configuration?
Best regards! Thank you !
liang
liang is offline   Reply With Quote
Old   March 13, 2010, 01:06
Hamid Zoka
Hamidzoka is on a distinguished road
Dear liang;
please check the followings:
-the right definition of adjacent inlet and out faces of rotor and stator
-the right definition of downstream and upstream faces
-the rigth definition of patch number for both faces
-in case you use "frozen rotor" or other unsteady approaches for rotor/stator interactions(except domain scaling method) verify that rotor and stator have the same periodicity.
in case you have completely perfomed the above commands and you still encounter with this error, please checkout your geometry definition.
does this help?
Hamidzoka is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
