Home > Forums > Software User Forums > Fidelity CFD
Numeca AutoGrid5
Old   July 11, 2007, 08:43
Default Numeca AutoGrid5
Atomizer
Hi I am trying to mesh a blade from an external cad file(ProE)in Numeca AutoGrid5. I can import and link it but when i try to Generate the Boundary layer(B2B), i get the message that my geometry is not fully defined and there is "no intersection curve detected". When i toggle 3D View i can see the whole blade and it seems to be correct.
Has anybody an idea?
Old   July 20, 2007, 12:12
Default Re: Numeca AutoGrid5
Stephan
Try to do the same in the AutoGrid4 environment and read in the created AG4-GeomTurbo again in AG5.
I also usually have problems by using Geometry data files to create a proper geometry in AG5 ...
Don't know what's the problem. AG4 usually helps if the coordinat system is orientated right.
Old   August 15, 2007, 00:54
Default what is isentropic mach number?
peck110
you clever guy please tell me the answer.i was confused by that.
Old   August 18, 2007, 21:28
Rikio
Did the extension have been set?
Old   March 13, 2010, 01:17
Hamid Zoka
Hamidzoka is on a distinguished road
this problem is probably due to relative positions of blade, hub and shroud lines. numeca can mesh the geometry only if blade geometry intersects with hub and shroud lines. please check this.
if your blade geometry does not intersect with hub and shroud lines, you can extend it from both sides inside the autogrid.
does it help?
regards
Hamidzoka is offline   Reply With Quote
CFX, Fluent and Numeca? SA FLUENT 3 March 22, 2008 14:46
Numeca Geometry? Jan Fidelity CFD 1 February 19, 2007 03:43
NUMECA vs CFX Iann Fidelity CFD 5 February 24, 2006 15:26
numeca & win 98 Neooo Fidelity CFD 1 December 5, 2003 11:57
Numeca Fine dimitris Main CFD Forum 5 June 17, 2001 11:43
