Home > Forums > Software User Forums > Fidelity CFD
autogrid:leading edge
Old   April 16, 2008, 22:14
Default autogrid:leading edge
liu wangkou
When I import the".dat"or".iges"files into the autogrid,the system will send out message"Discontinuity of 180 degrees in leading edge",What's wrong with this problem?
Old   July 18, 2008, 01:59
Default Re: autogrid:leading edge
Stephan
I suppose it has to do with the orientation of the geometry definition you are using. - Error messages of Numeca Products some times are not that clear. ...
Can you please give a closer specification of your input data !?
Old   August 22, 2008, 19:42
arthur
latest versions check the geometry when you link it to the mesh project... in this case all meridional curves are subject to an angle deviation check basically to try to identify loops in the curve, which will be impossible to mesh. With 180 degrees, your curve has a loop, most likely...
VFE-2 sharp leading edge model Abhishek Main CFD Forum 1 October 23, 2012 03:18
Leading edge separation and efficiency KK Main CFD Forum 2 December 3, 2008 06:19
leading edge vortices kaushik CFX 3 July 29, 2007 18:33
Radius leading edge problem Dadang CFX 1 April 20, 2004 01:35
Best leading edge for a Flat plate Rodge FLUENT 0 April 29, 2003 19:29
